bit more progress today :D
Ive removed all the beam axle and leaf springs of the van, ive also fitted the ifs front - in hindsight it might have been easier to use a mk3 the front holes are the same size as the mk1 20mm i think and the mk4 is 12mm - i think i will make some top hat shaped spacers to fit in the chassis hangers to reduce the holes to 12mm then weld them in
unfortunatly the bump stops are in the way now so ive got to remove them - not a problem but once i do that it's more difficult to go back
i also tried to fit my mk1 hubs to the mk4 discs and stub axle, the idea of this is to narrow the front track - which it will if it all fits as the mk1/2 hubs are narrower
unfortunatly the inner bearing is different, the outer is the same i think, also looking at it the mk3 one looks the same as the mk1/2 so again easier if i did a mk3 conversion, i may have to swap it to mk3 if i cant sort this but im gonna try get a bearing with the inner race the same as mk4 and the outer race the same as the mk1/2 if i can.
the reason i chose mk4 over mk3 is the mk4 has vented disks and better calipers, but does anyone know .............................
if mk4 disks/calipers can be fitted to mk3 or mk3 stub axle fitted to mk4
i prefer the mk4 shocker top mount and i'd like to keep that but can mk4 shockers fit mk3 or can mk3 shockers fit mk4 top mounts
