Applying window film tint
Re: Applying window film tint
Postby Rescue_marshal » Mon Dec 29, 2014 9:19 pm
Were the drivers passengers windows taken out to do or left in? Thinking of having a go as side rear windows already done. Don't forget peeps. If u lose to might light, I think more than 75% in drivers area the old bill can get you to remove it or fine you for it. In the uk any way.
Transit hi top 350 Lwb TD 2402
Rescue_marshal
Postby Peeteeb » Thu Feb 04, 2021 12:11 am
Thanks mate, I have two large windows to do...but low on the list!.
Peeteeb
Postby Redvee » Sat Jun 10, 2023 1:21 am
I applied reflective film to the side windows to Bessie, our minibus conversion, as we have some dry food on the window ledge of the van. I watched a few YT videos on how to do it and the last of the four windows I did was absolutely perfect, the first window less so. I took the wooden window frame out so I had better access to the rounded corners of the window, the hardest thing with Mk7 rear windows was the opening mechanism but I managed to take it off the window so I hada flat surface to work with, albeit with a hole.
Redvee
