Cosworth boa manaul box
Re: Cosworth boa manaul box
Postby Luke » Sun Jun 19, 2011 8:56 am
coming on 8)
not sure what to do with this starter :? very strange can you post up some pics of how it sits mabe we could spot something :?:
for the pas pump pipe i have them made up at a hydraulics place they charge £30-35 but i think they need the origanal transit one as the rack fitting isnt a standard hydraulic fitting :D
Postby rob hall » Sun Jun 19, 2011 10:45 pm
Thanks luke, ive been told to use a scorpio 2.3 starter as they have a built in gearbox
the welsh A-team!
rob hall
Postby rob hall » Wed Jun 22, 2011 6:55 pm
Right I think just think I might of found out why the starter wont work, the granada cosworth starter is 1.4 kvw but has 9 teeth
The transit pinto starter has 0.9 kvw and 10 teeth
Escort cosworth starter has 1.4kvw and 10 teeth :)
the welsh A-team!
rob hall
Postby rob hall » Fri Jul 01, 2011 1:27 pm
What throttle cable do I use?
the welsh A-team!
rob hall
Postby rob hall » Wed Jul 13, 2011 10:32 pm
Hi peps on the final two hurdles, oil filter.........and wiring.....
Due to my manifold mod my oil filter doesnt fit! Any ideas welcome?
the welsh A-team!
rob hall
Postby Luke » Thu Jul 14, 2011 5:32 pm
rob hall wrote:Hi peps on the final two hurdles, oil filter.........and wiring.....
are you still using the oil cooler :?: if not you can mount the filter direct to the block or get a relocation kit to have the oil filter in a different place :D
Postby rob hall » Thu Jul 14, 2011 5:58 pm
Yep still useing the cooler ,and order a mocal remote oil filter kit! :)
So just the wiring left!
the welsh A-team!
rob hall
Postby rob hall » Sat Jul 16, 2011 4:24 pm
I hate wiring!! Grrrr
the welsh A-team!
rob hall
Postby Luke » Sat Jul 16, 2011 4:32 pm
what diagram have you got :?: ive looked but cant find the one i used - it made it really easy too but ive got a copy of it somewhere :D
Postby rob hall » Sun Jul 17, 2011 6:02 pm
wireing diagram? Havent got one ! I just labeled everything before I took the loom out!
the welsh A-team!
rob hall
Postby Luke » Sun Jul 17, 2011 7:25 pm
rob hall wrote:wireing diagram? Havent got one ! I just labeled everything before I took the loom out!
theres loads on the loom you can thin out - i binned all the auto box loom the egr stuff also the air con - ends up as a nice small loom :lol:
Postby rob hall » Sun Jul 17, 2011 10:06 pm
Hmm I didnt of that!
Another thing was having problem with the starter I thought it wasnt strong enough to turn the engine but when I fitted my new high torque starter that was the same until I pressed the cluch and its fine then, what do you think the problem is with cluch? What can do 2 fix it?
the welsh A-team!
rob hall
Postby Luke » Sun Jul 17, 2011 10:15 pm
for the wiring go to http://www.fordpower.org.uk/forum2/ there is loads of 24v info on there :D
as for the clutch - odd one :? :!: sounds like the box is siezed but i guess that cant be it as you'll have used it before :?: also if you turn the input shaft when its in newtral does it turn ok and not turn the output shaft :?: i assume it does so in the installation you've got i'd be looking at mabe the alignment of the input shaft or something like that :? have you got any pics of it all :?:
Postby rob hall » Sun Jul 17, 2011 11:14 pm
What if I jack up the rear and turned the prop to see if it turns freely? As for the gearbox being seized, it could be possible as I havent used this box before as it was my spare one! It has been sat in my shed for bout a 8 months. Uu
the welsh A-team!
rob hall
Postby Luke » Sun Jul 17, 2011 11:18 pm
ok - jack the rear and with the van in neutral turn it over if the wheels turn then look further at the box might be the problem :(
