VAG 1.9 TDi into a RWD transit
Re: VAG 1.9 TDi into a RWD transit
Postby oldskooler » Thu Jun 18, 2015 10:16 am
awesome progress luke. ill be watching this thread like a hawk!!! :mrgreen:
oldskooler
Postby Luke » Fri Jun 19, 2015 8:46 pm
thanks mate - always good to see it done 1st make little improvements for when you do it :D i copied your idea for the gearbox crossmember but made it so its welded to the chassis and unbolts - if the engine has to come out after its finished it will need to be dropped below on both crossmemebers (because the box is so big) - doing it this will make it easier to locate :D
i might have an exhaust mount on here too and a coupling behind it - to make it easy to undo for engine removal :D
ive actually finished welding up the engine mounts but i cant get the pics off my phone - i will post them once i do. :D
Postby Luke » Fri Jun 19, 2015 9:25 pm
managed to get the pics of my phone :mrgreen:
this was modifying the front mk1 crossmember as the 1.9 sump is lower
1st marked it out took it off and cut it, then tacked in 2 angled box sections
then bolted it up back on the van - clamped it together and marked it out
then cut the piece out tacked it in in situ
then removed it ready for fully welding
Postby Luke » Fri Jun 19, 2015 9:32 pm
this picture shows the finished (not painted yet) crossmember - the circular disks were cut out of plate with a hole saw - they seat the passat engine mount rubbers, they also utilise the hole in the crossmember so they can be unbolted from underneith - bit of luck really :lol:
the engine mounts were made in the usual way - plates cut and bolted to the block then tacked to the mounts - removed and welded up :D the o/s one is an odd shape as it has to go round the starter motor. these need painting too but i want to check it all bolts up before painting them
tomorrows job is to bolt it all up so i have the engine sat on the mounts :mrgreen:
Postby BROWNYS V6 » Fri Jun 19, 2015 11:23 pm
nice bit of metal fab 8)
BROWNYS V6
Postby karl » Sat Jun 20, 2015 9:44 am
i agree nice work luke 8)
karl
Tranny Lover!!!
Postby Luke » Sat Jun 20, 2015 11:50 am
thanks guys :mrgreen: got it fitted and sat on the mounts now - i had to trim a bit back of each one to get them to fit but they are in now 8)
pics to follow 8)
the inlet manifold fouls on the servo :x does anyone know if all inlet manifolds are interchangeable :?: :?: just looking on ebay there are loads with the inlet pointing the other way that would do the trick :D
there isnt much room for the rad - it wont be able to go all the way across the front of the engine but i should have enough cooling area - if not i will have to fit twin rads - but i'd rather do that than chop out the bulkhead :)
Postby martynx » Sat Jun 20, 2015 12:20 pm
Some people use 2.0 SDI inlet manifolds on 1.9's. Fitting may be the same across all euro 3/4 1.9/2.0 Tdi /PD/SDI. Not sure though. ;)
I have an '01 non PD Leon if you need an inlet pic?
martynx
Postby Luke » Sat Jun 20, 2015 12:23 pm
i think they will swap like you say - ive found this one on ebay for £15 might just take a risk
http://www.ebay.co.uk/itm/VW-TOURAN-GOL ... 463bc40be3
Postby martynx » Sat Jun 20, 2015 12:31 pm
Luke wrote:i think they will swap like you say - ive found this one on ebay for £15 might just take a risk
Can't go wrong at 15 quid ;)
martynx
Postby Luke » Sat Jun 20, 2015 12:32 pm
o/s mount - you have to remove the turbo support strut to get the starter out :roll: but ive seen worse on mass production cars :lol:
n/s mount - you can see from the other pic how ive had to trim off the top support - still plenty strong enough :D
Postby Luke » Sat Jun 20, 2015 12:35 pm
and the engine 8) sat on all the mounts
you can see the inlet fouling on the servo - obviously plenty of space above the engine :D
there looks a lot of space in front for the rad but once the panels on its very tight :x
Postby Luke » Sat Jun 20, 2015 5:50 pm
i took the inlet manifold off and it looks the same so i bought it - fingers crossed :D
decided to fit a Lotus Elan M100 radiator - bit expensive but it will fit all the way across the front of the engine - only downside is i will have to relocate the alternator lower down so i'll need to make a bracket for it :)
the 2 pipes running across the front of the engine are i believe the fuel cooler radiator - i'm hoping i dont have to fit this as i have a metal tank and i think its because the passat has a plastic tank and the returning fuel can get hot :?
Postby Luke » Sat Jun 20, 2015 10:12 pm
ive taken the gearbox back off and fitted the adapter plate - all lines up perfect 8)
but the crafter starter wont mesh to the passat flywheel :x means i'll have to buy a crafter DMF flywheel and clutch
also looking at the gearbox sensors on the passat i think all they are is reversing lights and speedo - there is no sensors on the crafter box - for the speedo i will use a gps one until i get the original one sorted and i dont think i need reversing lights for MOT but they might be on the stick?
it would have been easier to do this with an MT75 as the speedo drive and reverse lights would be there :D
Postby Marty.H » Sat Jun 20, 2015 10:43 pm
No reverse lights needed for MOT :)
Marty.H
