My Essex V6 Transplant
Re: My Essex V6 Transplant
Postby Leeday » Tue Mar 25, 2014 1:08 pm
bobdragon12 wrote:http://www.ebay.co.uk/itm/FORD-MT75-TRANSMISSION-4X4-SIERRA-COSWORTH-2-9-V6-XR4X4-GEARBOX-MAIN-SHAFT-/310783455891?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item485c233293
Only need the input shaft, this is the main shaft. This project is costing a fortune already :shock: parts, 3 weeks off work :shock:
1989 Mk3 swb, 3.0 V6 Essex, 5 Speed Manual: http://fordtransit.org/forum/viewtopic. ... 3&t=142054
2005 Mk6 2.0 Duratorq 100 T350 MWB Semi High
Leeday
Postby Leeday » Tue Mar 25, 2014 1:09 pm
bobdragon12 wrote:You can tell its a busy day at work :D
http://www.super7thheaven.co.uk/MT75_Gearbox
This has full drawings for the various boxes
Loving this site :D
Leeday
Postby Leeday » Tue Mar 25, 2014 1:16 pm
This picture also shows the input shaft protruding and the splines level with the front face of the gearbox, which would be correct:
Mine is set back:
Leeday
Postby Leeday » Tue Mar 25, 2014 1:23 pm
bobdragon12 wrote:Bloody expensive though , where did your mt75 come from ? Is there anything up cliftongrade with the engine out so you can look at the difference ?
The only Transit in Clifton grade is the tipper, its a 2.5 diesel with MT75 gearbox, but they are attached to each other and the van has its front wheel hub sat on 3 wheels .. that's all that's keeping it in the air.... bit wobbly when I was removing the prop mount, would be well scary dropping the gearbox out :lol:
Leeday
Postby bobdragon12 » Tue Mar 25, 2014 1:25 pm
have you tried Rookly , they may have one already out ?
MK2 LHD coachbuilt Camper 2.5TDI
bobdragon12
there were 2 LDV's up at cliftongrade
bobdragon12
Postby dieselhead123 » Tue Mar 25, 2014 1:27 pm
PM'd you my findings from your info mate.
Package in the post!
I do think that I gave you the wrong clutch cover, another I tried here this morning seems to have fingers raised more than the dims you have taken. :oops:
Your flywheel does appear the same as one I have here, using it to do a 'dry run', the clutch splines are ok, the center plate hardly moves during dissengagement.
Moving the 'ball' pivot for the release arm forward will do the job and move the cable end of the clutch arm backwards away from the bell housing, the clutch arms without the cast 'lump' do give more movement as they are not as bulky at the cable end. I am sure this is the type we had on Robbies.
We will get to the bottom of this mate,
Postby Leeday » Tue Mar 25, 2014 2:26 pm
bobdragon12 wrote:have you tried Rookly , they may have one already out ?
Where abouts is the yard in Rookley?
Leeday
Postby bobdragon12 » Tue Mar 25, 2014 3:42 pm
island auto salvage , in the estate apposite the co-op ( i think there still trading )
bobdragon12
Postby Leeday » Tue Mar 25, 2014 4:16 pm
bobdragon12 wrote:island auto salvage , in the estate apposite the co-op ( i think there still trading )
Great stuff, cheers :D will have to have a drive out and check it out.
Leeday
Postby bobdragon12 » Tue Mar 25, 2014 4:37 pm
Let me know how you get on , and if you need a engine hoist PM more than happy to lend you mine
bobdragon12
Postby robbie.cee » Tue Mar 25, 2014 4:46 pm
My clutch arm was standard late di type with the big weight on the end(which ended up needing welding in place!)
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby Leeday » Tue Mar 25, 2014 6:31 pm
bobdragon12 wrote:Let me know how you get on , and if you need a engine hoist PM more than happy to lend you mine
Many thanks, Much Appreciated 8)
Leeday
Postby Leeday » Tue Mar 25, 2014 6:33 pm
robbie.cee wrote:My clutch arm was standard late di type with the big weight on the end(which ended up needing welding in place!)
Yes, Think that`s the one I got as well, big chunky black bit on the end of the arm that the cable fits into.
Leeday
Postby Leeday » Tue Mar 25, 2014 8:51 pm
Well a day of measuring, thinking, phoning, thinking, measuring again :? Engine still not in:
My input shaft and clutch release bearing issues:
Clutch release bearing in its further backwards position (release arm at clutch cable end hitting back of gearbox cut-out):
and at its furthest forward position (release arm at clutch cable end hitting front of gearbox cut out):
So near, yet so far :roll:
Leeday
