yet another v6 question
Postby BLADEBEATEREATER » Sat Nov 18, 2006 5:46 pm
Hi yawl
been away for a while now i'm back
i've just aquired a 2.9 v6 and now i'm collecting info on how to fit it in to my mk3. all i have is a efi engine and a mk3 with a 2litre pinto installed, i know a few of you have done this so can anyone tell me a list of parts i need
thanx in advance rich
IF YOUR GONNA DIE, DIE WITH YOUR BOOTS ON
BLADEBEATEREATER
Postby Guy88 » Sat Nov 18, 2006 5:59 pm
Is your new engine a 12v :?
For the 24v you need
Engine
Loom
ECU
adaptor plate
Engine mounts
flywheel the correct size (or redrill pinto one)
I am doing a 24v cosworth at the moment.
If you are using a Type 9 or an auto its easier 8)
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Guy's 24v
Postby dipstick » Sun Nov 19, 2006 11:30 am
... :) How is yours coming along Guy...?
A word of caution, though i hope you don't need it... :)
i removed the fuel rail on my BOB 24v to get then injectors out to clean them.....nightmare.....they are 'welded' into the rail, due to the heat and varnish in the fuel, the O rings have locked sold.....
A week of penetrating spray both 'ends' and eventually they came out, by holding the head of the injectors in a vice and twisting off the rail, but i broke one injector! :(
needless to say they are unobtainable from anyone new , so i had to beg on the FORDPOWER-UK site..... keep your eyes out.....
good luck
dipstick
Cosworth Powered
Cosworth Powered
Postby Luke » Sun Nov 19, 2006 12:48 pm
are you wanting to do a 24v or 12v conversion?
and do you want to go auto or manual?
Re: Guy's 24v
Postby Guy88 » Sun Nov 19, 2006 2:49 pm
dipstick wrote:... :) How is yours coming along Guy...?
good luck
I am waiting for my redrilled flywheel then it just need the mounts welding properly and it will be in for good :D
I read about your probs on ford power :P
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
BOB Injectors....
Postby dipstick » Sun Nov 19, 2006 6:21 pm
... hmmmmmm .... gutted i was...... :(
I think i have a couple 'spares' coming ...... :)
good luck :-)
dipstick
Cosworth Powered
Cosworth Powered
Postby BLADEBEATEREATER » Sun Nov 19, 2006 7:04 pm
ITS A 12v EFI, NOT SURE WETHER TO CONVERT TO CARB FOR SIMPLISITY, AND WOULD RATHER USE A MANUAL GEARBOX
BLADEBEATEREATER
Postby dipstick » Sun Nov 19, 2006 7:11 pm
.....if you want a manual box, you will need the adapter plate for a V6 to MT75, or use a 'car' MT75 and reversed linkage.....
:-) cheers
dipstick
Cosworth Powered
Cosworth Powered
Postby Luke » Sun Nov 19, 2006 7:48 pm
dipstick wrote:.....if you want a manual box, you will need the adapter plate for a V6 to MT75, or use a 'car' MT75 and reversed linkage.....
:-) cheers
or a type 9 box :D
Postby BLADEBEATEREATER » Tue Dec 05, 2006 10:14 pm
SORRY TO BE A PLEB BUT WHATS THE DIFFERANCE IN THE VAN AND THE CAR MT75'S
ALSO WHERE CAN I GET AN ADAPTER FROM???????????
BLADEBEATEREATER
Postby MrMPuk » Tue Dec 05, 2006 10:31 pm
BLADEBEATEREATER wrote:SORRY TO BE A PLEB BUT WHATS THE DIFFERANCE IN THE VAN AND THE CAR MT75's
On the car box the gearstick is behind the box and on the van box it is on top.
Also, NO NEED TO SHOUT.
Postby Guy88 » Tue Dec 05, 2006 10:40 pm
Pinto one can be re drilled or a V6 ambulance MK3 :wink:
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby BLADEBEATEREATER » Tue Dec 05, 2006 10:40 pm
sorry caps lock stuck on
so apart from that the bolt patern is the same ?
BLADEBEATEREATER
Postby MrMPuk » Tue Dec 05, 2006 10:42 pm
When you say Mk3 ambulance you mean a later one as the early ones were Essex engined and would have had the 4 speed overdrive box.
Postby Guy88 » Tue Dec 05, 2006 10:44 pm
Yep and was an SVO order on MK4 :shock: :wink:
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
