mk5 steering wheel
mk5 steering wheel
Postby OssettGeezer » Wed May 30, 2012 10:09 pm
Anybody know if you can change the steering wheel to one from either a granada or sierra? the standard one looks crap and is quite large.
cheers all.
OssettGeezer
Re: mk5 steering wheel
Postby Luke » Wed May 30, 2012 10:45 pm
no neither will fit - what you need is an escort mk1 (not mk2) or capri - then grind out the master spline on the transit column :D
also subaru ones fit apparantly but i dont know which ones :D
Postby OssettGeezer » Thu May 31, 2012 11:56 am
ok, thanks for that.Would there be an aftermarket boss kit you can buy instead?
OssettGeezer
Postby jay » Thu May 31, 2012 1:01 pm
yes aftermarket for capri fits..I think the subaru one is the early wrx up to about 97 is the same size after that the steering coloumn is diffrent size(but measure before buying 1)
mk1 connect tourneo
jay
