by Aardvark » Sat Jul 21, 2012 3:14 pm
Well basically you just cut a large crescent out of paper and offer it up. As you bend it to meet the bodywork you will see its a mile off in most dimensions so you make notes at various points on it how much needs to be added, and how much needs to be cut off to improve it. Stick this first template on another sheet of paper and make the changes on that and cut it out. Offer it up and it will be a bit better than the first one. Mark it up with more corrections and then cut another until you get one that you are happy with. Then lay that on your metal as a template and mark and cut out. You can do two, just remember to flip the paper over for the second one, it should be a mirror image that you can use on the other side of the van. Do the whole process again for the opposite end of the van and make two again so you have both sides matching. How you get around the side loader problem is going to be a compromise between having a nice wide arch to cover wide tyres and having a functional side loader. Some guys have modified the door a bit at the bottom and others say it may be possible to alter the track or the roller mechanism that runs in it to bring the door out away from the body a bit. It will take a lot of patience and if you make a good job of it they guys on here will be well impressed.
Learning to love rust.........
