Has anybody fitted one to there transits for novilty?
As i would like to do it to mine.
Cheers.
nick217 wrote:Has anybody fitted one to there transits for novilty?
Cheers.
robbie.cee wrote:nick217 wrote:Has anybody fitted one to there transits for novilty?
Cheers.
yes and the new am/fm cb i got also has 100w pa horn attached to it via an ex fuzz amplifier!!![]()
maplins do a nice 5 foot whip for £15
blue meanie wrote:am fitting a uhf 40 channel today.got antenna and mounting bracket from auto parts store.had a choice of 2 types of bracket the cheap one that means drilling holes and bolting up or the dearer gutter mount type.went with gutter type as fully adjustable with hex key and easy fit.will just pop bit of old innertube under clamp so not to damage paint.no doubt chaos is about to unfold in these parts
SNOWDOG wrote:So, is there a 'starter rig' anyone might recommend ?
is it best to wire them in or use the cigar lighter cable some are supplied with ?
where would be a good mount point in a mk6? had fancied using the little cubby on top of the dash but am guessing that as the speaker seems to be mounted on the bottom of these units it wouldnt be ideal??
also, are the dinky little 'discreet' antenna any good![]()
would just be for listening to the 'crack' down the motorways![]()
thanks.
robbie.cee wrote:SNOWDOG wrote:So, is there a 'starter rig' anyone might recommend ?
thanks.
Cubby good place to mount. Speakers are crap anyways, get a cheap external speaker plugs in rear
Longest poss Ariel best! use good co ax wire too
Personally I'd power off a spare fuse in fusebox
