side loading door
side loading door
Postby bondyfnm » Wed Sep 04, 2013 9:24 pm
Hello peeps, I was trial fitting my new modulars the other day and the side loading door fouls them.
Just wonderd if there's a thread about solutions to fix this on my smiley.
If not has anybody got any suggestions? :roll:
MK5 lwb 190 hi top
MK5 swb 100 project
MK1 capri project
bondyfnm
Re: side loading door
Postby Aardvark » Fri Sep 06, 2013 7:08 pm
This question has been asked many times.............
Never gets an answer...........
Gull wing mod the side loader on gas rams?
Space out the slider rail from the body?
Cut a large notch out of the offending corner of the door and weld it back onto the body?
Lengthen the wheelbase? :wink:
Learning to love rust.........
Aardvark
Postby AlanN » Sun Sep 08, 2013 8:17 pm
Transit modulars have an offset for the Transit MK2/3, which have narrower axles which allows for banding and 245/255 tyres. Fitting a narrower tyre will help, but if you have redrilled Land Rover Modulars then the offset is even wider, packing the rail will help a little, but Ive never heard of anyone cutting the door down, but its an option :D
Postby Aardvark » Mon Sep 09, 2013 12:13 pm
Cutting the door was a trick we used in the 70's-80's when fitting ridiculously wide tyres and then fabricating big arches to cover them. Its a lot of work cutting, shutting, and then re-shaping the door seal but it works.
Aardvark
cron
