Any idea how difficult a 2.4 TDCI 140 into MK2 Di would be?
Postby BEHEMOTH » Thu Apr 05, 2007 7:20 pm
Like the title suggests, i'm wondering how crazy the idea of putting a 2.4 duratorq MK7 engine into a MK2 relly is? Obviously there'd have to be a fair bit of custon engineering done but does anyone have any thoughts on this?
BEHEMOTH
Postby BigNeil » Thu Apr 05, 2007 7:31 pm
why not do it the other way and put a Mk2 body on a mk7 :D
BigNeil
Postby Guy88 » Thu Apr 05, 2007 7:50 pm
Transitgeoff has a MK6 TDDi in a MK1 :wink:
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby Luke » Thu Apr 05, 2007 11:24 pm
anythings possable and like guy says geoffs fitted one so you know it will go in :D
Postby Neil » Fri Apr 06, 2007 12:47 pm
go the easy way 2.5 di it will last longer too
Neil v6
Neil
Postby motorwise » Fri Apr 06, 2007 1:35 pm
Neil wrote:go the easy way 2.5 di it will last longer too
let me see - clean quiet, refined and powerful against gutless and noisey - I'd stick with the duratorq :wink:
http://www.motorwise.net
motorwise
Postby madmark » Fri Apr 06, 2007 2:53 pm
:lol: wow if i had my mk6 engine in the mk1 it would leave the shell behind at the lights :lol: :lol:
Postby Neil » Fri Apr 06, 2007 4:25 pm
your right but the di will be noisy when the duratorqes long gone
Neil v6
Neil
Postby FredTransit » Fri Apr 06, 2007 6:23 pm
I agree with you there Neil. Three little letters - DMF.
FredTransit
Mk2 Trannyist
Postby motorwise » Fri Apr 06, 2007 7:43 pm
that can soon be changed for a solid flywheel :D
motorwise
Postby FredTransit » Fri Apr 06, 2007 8:33 pm
OK, three more little letters - CPU. Then sensors, heat sesitivity, fuel pump, the gearbox it's attached to........
FredTransit
Mk2 Trannyist
Postby motorwise » Fri Apr 06, 2007 8:47 pm
FredTransit wrote:OK, three more little letters - CPU. Then sensors, heat sesitivity, fuel pump, the gearbox it's attached to........
not a great duratorq fan then :lol:
motorwise
Postby FredTransit » Fri Apr 06, 2007 9:47 pm
no.
FredTransit
Mk2 Trannyist
Postby School Boy » Fri Apr 06, 2007 10:00 pm
Can you elaborate please, sounds interesting.
School Boy
Under age driver!!
Under age driver!!
Postby FredTransit » Fri Apr 06, 2007 11:18 pm
Which bit? Mk2 running a duratorq? Sticking with the DI? DI V Duratorq? Duratorq relyability (or lack of)?
FredTransit
Mk2 Trannyist
