Pictures of all available correct size pcd Transit alloys
Re: Pictures of all available correct size pcd Transit alloy
Postby Simon 73 » Mon May 09, 2016 11:36 pm
I fitted these 18inch wolf race alloys to my custom they look stunning on the van
Simon 73
Postby wojciech » Mon May 23, 2016 8:57 am
From thread Twin wheel alloys viewtopic.php?f=13&t=170186
Image Image
Producer: ALCOA USA, model 26180x, PCD 6 x 180mm, bolt hole diameter 23mm, hub bore 138,8mm, offset inset 110mm, offset outset 124mm, max. load 925kg
http://www.alcoa.com/alcoawheels/catalog/pdf/brochures/alcoa-m-series-wheels-for-transit-vehicles.pdf
Image Image
Producer: ALCOA USA, model 26190x, PCD 5 x 160mm, bolt hole diameter 16,5mm, hub bore 65,1mm, offset 60mm, max load 1270kg
wojciech
Postby wojciech » Wed Aug 03, 2016 10:12 am
Brand : Wolfrace
Model : TTR/ Explorer LRD
Width : 7J
Diameter : 16 Inch
Bolt Pattern : 5x160
Offset : 50
Colour : Hyper Silver, Gloss Black, Gunmetal
Style : 10 Spoke
http://www.wolfrace.com/product/wolfrac ... rettyPhoto
http://www.wheelbasealloys.com/alloy-wh ... er/16-inch
Image Image
wojciech
Postby wojciech » Fri Aug 05, 2016 9:29 am
There is no accounting for taste. But...
Wolfrace TTR are the coolest alloys in Transit history - I think. Maybe only old Ronals for Mk3 are equally nice.
Relative to OM alloys for Mk6/7, TTR have outside rim 25 mm more sideward. They are looking together mighty and elegantly. Perfect wheels for heavy van.
Excellent deseign... Image
wojciech
Postby Daniel Breed » Sun Aug 14, 2016 4:28 pm
Daniel Breed
Postby wojciech » Fri Sep 30, 2016 8:24 am
CARRE SATURN
Rim size 8Jx18"
PCD 5x160mm
ET 50mm
Weight load 1.250 kgs (per wheel)
wojciech
Postby wojciech » Fri Sep 30, 2016 8:42 am
Team Dynamics
model Piranha
Rim size 7.5x18"
Offset 50mm
PCD 5x160mm
Colour Gloss Black Machine Face
wojciech
Postby wojciech » Fri Sep 30, 2016 8:58 am
Borbet model CW3
Rim size 7,5x18"
Offset 50mm
PCD 5x160 mm
Colour: Silver Polished Rim, Gloss Black Polished Rim or Satin Black with Polished/Red Rim
Image Image Image
wojciech
Postby DAMBUSTER » Tue Jan 03, 2017 9:13 am
What nuts you guys using on alloys? Iv'e got a set of 16" Team Dynamics Rimfire's for my Mk6 with flat nut seats, Thanks
DAMBUSTER
Postby wojciech » Sun Jan 15, 2017 9:39 pm
DAMBUSTER wrote:What nuts you guys using on alloys? Iv'e got a set of 16" Team Dynamics Rimfire's for my Mk6 with flat nut seats, Thanks
FORD TRANSIT SOLID CHROME WHEEL NUT NUTS 2000 ON M14 SET OF 10 MK6 2.0 2.3 2.4
£ 29.95 - SOLD (fixed price)
Ended Mon Apr 27th  9:49pm BST
Seller: transitpartsuk
or genuine fords alloy nuts - much, much more expensive.
Nuts from ebay are better - they are monolithic, genuine nuts have tinny chrome overlay, not so strong.
wojciech
Postby wojciech » Tue Feb 14, 2017 11:42 am
Producer: Wolfrace, type: FTR, size 8Jx18", load 1.350kg, PCD 5x160mm.
Finishing: Gloss Black / Polished Face, Gloss Black / Polished Tips, Gunmetal / Polished Tips, Hyper Silver, Satin Black.
wojciech
Postby wojciech » Tue Feb 14, 2017 11:43 am
Producer: Riviera, type: Dizzard, size 8Jx18", FT 50mm, PCD 5x160mm.
wojciech
Postby wojciech » Sun Feb 26, 2017 6:07 pm
Unknown producer/model, size 6,5Jx15", PCD 5x160mmm, ET 53 mm.
wojciech
Postby wojciech » Thu May 04, 2017 8:59 pm
RIAL Leichtmetallfelgen Germany, model Transporter, size 6,5Jx16, ET 60mm, PCD 5x160mm, load 1.450 kg
wojciech
Postby wojciech » Fri Sep 01, 2017 10:11 am
TEAM DYNAMICS model PIRANHA ST, size 7,5Jx18", PCD 5x160 mm, offset 50 mm, finishing : Black Polished, Gloss Black.
Once more time, more pictures
wojciech
