No Pictures - available correct size pcd Transit alloys
Re: Pictures of all available correct size pcd Transit alloy
Postby wojciech » Thu May 17, 2018 5:25 pm
DEZENT Wheels - Member of the ALCAR, model Van and Van Dark, size 6.5Jx16", PCD 5 x 160 mm, ET 60 mm, load 1.350 kg
Image Image
wojciech
Postby wojciech » Fri May 18, 2018 8:34 am
Riviera model Trekker, size 8.0Jx18", PCD 5 x 160 mm, ET 45 mm, load 1.050 kg.
wojciech
Postby wojciech » Fri May 18, 2018 9:01 am
RIVIERA, model VIGOR , size 7,5Jx18", PCD 5 x 160 mm, ET 45 mm, centre bore 72,6 mm, or size 8,0Jx20", PCD 5 x 160 mm, ET 50 mm, centre bore 72,6 mm. Both versions have very low load - only 850 kg
wojciech
Postby wojciech » Fri May 18, 2018 9:22 am
Riviera model RTS, size 8.0Jx20", PCD 5 x 160 mm, ET 50 mm - "available in a range of finishes" (?)
wojciech
Postby wojciech » Fri May 18, 2018 9:30 am
Riviera model RTT, size 8.0Jx20", PCD 5 x 160 mm, ET 50 mm, load 900 kg
wojciech
Postby wojciech » Sun May 20, 2018 9:03 am
ORC, model Felge Typ 33, size 8.5Jx18", PCD 5 x 160mm, ET 48 mm, very high load 1,380 kg = 3,042 lbs
Producer intends tires for Ford Transit Custom 235/ 50 R18 101 V or 235/ 55 R18 104 V, for Ford Transit 235/ 55 R18 104 V or 255/ 55 R 18 109H, for heavy versions 255/ 55 R 18CP 120 T.
wojciech
Postby wojciech » Sun May 20, 2018 3:14 pm
Once more about ORC model Felge Typ 170, size 8Jx18", PCD 5 x 160 mm, ET 48 mm
Producer intends for Ford Transit Custom tires 235/ 50 R 18 101 W, for Ford Transit 255/55 R 18 109 or 255/55 R 18 C 116 T for heavy versions.
wojciech
Postby wojciech » Mon May 21, 2018 8:33 am
ARCASTING model AVATAR, size 6,5Jx16, PCD 5 x 160 mm, ET 50 mm, finishing : Silver oraz Black Diamond
wojciech
Postby wojciech » Mon May 21, 2018 9:05 pm
Once more MAK model Fuoco 5, size 6.5Jx15", ET 52 or 58 mm and 6.5Jx16" ET 60 mm, PCD 5 x 160 mm, finishing: Hyper Silver, Ice Titan., Ice Black
wojciech
Postby wojciech » Mon May 21, 2018 9:19 pm
MAK model Stone 5, size 6,5Jx16" ET 55mm and 7.0Jx17" ET 60 mm and 7.5Jx17" ET 52 mm, PCD 5 x 160 mm, finishing: Silver or Brillant Black/Mirror Face
wojciech
Postby wojciech » Tue May 22, 2018 4:30 pm
One more time: JBW, model 18LMBS160 Lambo , size 8.0Jx18", PCD 5 x 160 mm, ET 45 mm, finising: Hypersilver, Matt-black, Gloss-black, load 850 kg.
wojciech
Postby wojciech » Tue May 22, 2018 5:38 pm
Black Rhino, model Journey, size 7.5Jx16" and 7.5Jx17" ET 45 mm, 8.0Jx18" ET 48 mm, PCD 5 x 160 mm, finishing: Black Matte or Machine Gunmetal.
wojciech
Postby wojciech » Wed May 23, 2018 6:21 pm
Wolfrace model AD5T, size 8Jx18", ET 50 mm, PCD 5 x 160 mm, Centre Bore 110 mm, finishing: Silver / Polished, Gunmetal / Polished, Gloss Black, Glos Black/Polished, load 1.250 kg
wojciech
Postby wojciech » Sun May 27, 2018 5:14 pm
Moto Metal, model M0970, size 7Jx16" and 8Jx17", ET 42mm, PCD 5 x 160 mm, load rated 3.000 lbs (1.360 kg), finishing Gloss Black w/Machined face, Gloss Gray Center w/GlossBlack Lip, PVD, Satin Black Milled
wojciech
Postby wojciech » Sun May 27, 2018 5:24 pm
KMC Wheels, model XD820, size 7.0Jx16" ET42mm, 7.5Jx17", ET45mm, 8.0Jx18" ET 48mm, PCD 5 x 160 mm, finishing: Satin Black, Satin Black w/Machined face, PVD, Satin Black Milled.
wojciech
