Pictures of all available correct size pcd Transit alloys
Re: Pictures of all available correct size pcd Transit alloy
Postby wojciech » Sun Jun 03, 2018 6:29 pm
Vision Wheel model 375 Warrior size 7,5Jx18", PCD 5x160, ET 55 mm, finishing: Phantom Chrome, Black Machined or Gloss Black Machined Face
wojciech
Postby wojciech » Sun Jun 03, 2018 7:03 pm
Ultra Wheels Co. model 450SB Toil Van , size 8,0Jx17", PCD 5x160, ET 50mm or 6,5Jx16" ET 45 mm, finishing: Satin Black Wheel or Chrome Wheel Rim
Another version: Gear Alloy model 750BM Sprinter, size 8,0Jx17", PCD 5x160, ET 50mm, finishing: Black/Milled Wheel Rim
wojciech
Postby wojciech » Wed Sep 12, 2018 3:56 pm
Mk6 alloys on Mk5
wojciech
Postby wojciech » Sat Sep 15, 2018 8:31 pm
Some new interesting pictures about Alcoa alloys - for dual wheels models. https://www.arconic.com/alcoawheels/cat ... hicles.pdf
Images that was taken by user WildThing from USA Ford Transit Forum.
He wrote:
"Finally got the Duratrac tires on the 350 HD, I used LT225/75R16. These will not fit the rears on the stock rims but with the Alcoa wheels they fit perfectly. Lock to lock, no rub in the front and the backs fit with 1/2 inch clearance on the inside to the leaf spring, and the center gap is 1/8th of a inch at low pressure. It handles amazing, I am very happy that my measurements were correct!"
wojciech
Postby wojciech » Sat Sep 15, 2018 8:43 pm
Ronals R44 on Mk8 4x4 (6,5Jx16, ET 60mm, load 1.150 kg for alloys with tapered sockets, for alloys with flat sockets was 1.300 kg)
wojciech
