moving a fuel filler cap
Postby bigyellow » Thu Mar 19, 2015 11:05 am
has anyone ever moved a fuel filler cap off the door column to inside the van for security reasons or has found a better way to secure the fuel filler cap and the underneath of the fuel tank
does anyone have any pictures or links for this details
bigyellow
Re: moving a fuel filler cap
Postby ake » Sun Mar 22, 2015 8:48 pm
There's no point moving the filler, the tank and pipes are plastic, and can easily be cut.
On the plus side, because fuel is cheaper just now, thefts have dropped.
Postby bigyellow » Sun Mar 22, 2015 11:01 pm
whilst i see the logic, i dont understand why they still have plastic cover caps and no one does a replacement steel or strong version.
you would have thought someone would have done an under cover kit for them,
every security issue seams to have someone flogging me a solution for it
bigyellow
Postby Skut_monkey » Tue Mar 24, 2015 11:45 am
A lot of boy racers used to do it in the 90's
Moved behind rear clusters or just a fuel cell in the boot
Skut_monkey
Postby bigyellow » Tue Mar 24, 2015 2:53 pm
all i was thinking was a 90 degree bend to it that's all to turn it so its facing inside the cargo area not outside
and then we mentioned puncturing fuel tanks which i had not thought of so its a case then of some form of under tray for it.
i can remember hearing when diesel was well expensive that people were draining tanks all the time. i was expecting that someone had designed a stainless steel cover that bolts underneath it with sides to protect someone drilling into the tank base.
so i was expecting to see one second hand some where that's all, 1.5mm of stainless or 2mm even is pretty well strong enough to prevent idiots and battery drills
i had not thought of it as a modification for visual purposes only, i shall have a look and see what was done in the modding scene.
it only came about because we were discussing dropping the diesel tank out one day to under-seal above it and to add the extra fuel valves and the linkages pipe work for the second tank.
we have not started work yet its a case of working out what we want to do exactly before we start works. i could be a diesel tank millionaire next week when i start selling them, lol
can you patient a stainless steel biscuit tin lid
bigyellow
Postby Skut_monkey » Tue Mar 24, 2015 6:27 pm
Bend upa sheet of chequerplate to use as tank armour, its only stopping dickheads with a screwdriver punching a hole in it, then do what you want with the neck
Skut_monkey
Postby bigyellow » Tue Mar 24, 2015 9:58 pm
i shall next time its on the ramps get under it and take a load of pictures and measure the areas involved and look into it
maybe theres a business in it and other vans too :lol: :lol:
bigyellow
