transit lowering
transit lowering
Postby rallynut01 » Sun May 20, 2007 6:51 pm
Hi i am new to the van scene and have a mk5 swb and whant to lower the van it will never be carrying anything heavy so weight rating is not important
rallynut01
Postby Luke » Sun May 20, 2007 6:53 pm
have a search of the forum :arrow: http://www.fordtransit.org/forum/search.php
there is quite a bit of info on here already :D
Postby WRECKERSTEVE » Wed Jul 11, 2007 8:05 pm
i have fitted lowered rear leaves and cut 2" from front coils the idea was to improve the look 8) compare before and after :) the rears were supplied by gme and are recambered 6" i fitted them and they looked no different so quick call 2 gme and we agreed to take out 3rd leaf refit van after paint and if 2 low refit said leaf. fronts are to see if 4"drop enough spring situated midway between b/joint and pivot point on wishbone so 2" on coil 4" at wheel in theory again see what it sits like rebuilt then a firm recommended by gme will make me rewound springs to suit only other problem is shocks may bottom out but these can be made shorter LEDA http://s164.photobucket.com/albums/u31/ ... G_3594.jpg http://s164.photobucket.com/albums/u31/ ... G_3749.jpg
you break it i take it
WRECKERSTEVE
