You can see in the picture below where the cable has been cut.
I've knocked up a thick steel channel to protect the exposed part, just needs painting after it's welded on to the new winder
S26coolin wrote:So how does this stop them cutting it further down the cable?
shovelheadrob wrote:Holy thread resurrection Batman! I did think about knocking a few out & even offered them to my local Ford Transit dealer, but it's only a bit of box section steel shaped to the profile of the winder mechanism, then welded on so easy to make if you can weld or know someone who does. Touch wood it's worked as I still have the same spare wheel 2 years down the road!
