Hello, I planning some ground clearance with my mk6 350 lwb 90 these are my ideas and I would be grateful for some guidance!
So I'm going to up the tire size, using bf TA's , but I don't know what I'd get away with.
215/75/r16's is the standard size. am I dreaming with the hope of 235/785r16?
Or I could down size to r15's and get the bigger tires?
I need a preferably common size.
I'm planing raising the suspension for the front can I (simply?) bang some spacers on the springs...has anyone else done this, is this a good way of doing things?
The rear I plan either blocks with longer U bolts or another leaf from somewhere...
On the rear axle I'd like to raise/move the rear shock mounts as they hang to low, could I just weld them higher and everything be cool as the suspension should also be raised?
Or
Could I swap the rear axle for something else, preferably with a mechanical diff lock maybe a ford ranger.
Many thanks for you help in advance
