Lsd axle swap
Lsd axle swap
Postby rob hall » Fri Dec 18, 2015 11:53 am
As there isnt any lsd unit to fit a mk6 transit does anyone on here have any of a simlar lsd axle that i to could modify to fit?
the welsh A-team!
rob hall
Re: Lsd axle swap
Postby rob hall » Fri Dec 18, 2015 11:54 am
Axle swap
the welsh A-team!
rob hall
Re: Lsd axle swap
Postby Illiterate_husband » Tue Dec 22, 2015 8:49 pm
I have hunted high and low to find out if someone else has done this already,, well for a locking diff, As much as I'd love to I haven't the finances or work space to experiment with.
Illiterate_husband
Re: Lsd axle swap
Postby john yates » Wed Feb 10, 2016 8:18 pm
Not sure about mk 6 but definitely available for mk 5 as I'm about to fit one to mine, minormatt will know I imagine.
john yates
Re: Lsd axle swap
Postby Davcotts » Sat Apr 23, 2016 9:33 pm
The 6 speed mk6 rwd's have a dana spicer diff and LSD units are available for this at between £300 and £1000 depending on ratio and intended use.
Davcotts
Re: Lsd axle swap
Postby rob hall » Fri Jun 10, 2016 9:35 pm
I cant find any spicer diff lsd units ??
Are you sure?
the welsh A-team!
rob hall
Re: Lsd axle swap
Postby norfolkandgood » Sun Jun 19, 2016 7:25 pm
https://www.ringpinion.com/b2c/partslis ... 5&CatID=38
http://automotiveaftermarketnews.com/f2 ... -posi.html
Don't know if any of these are what you are looking for but worth a look, getting stuff from the states isn't too bad.
Post up here if you find anything suitable even if you aren't going to buy I am interested to know.
Cheers.
norfolkandgood
