Rev Counter and Escort Clocks
Postby stuntmaster » Sun Jun 10, 2007 11:31 pm
after reading on here about those mondeo clocks, brought me to the rev counter thing.
If lets say i have the 3 pin alternator, how easy would it be to add a rev counter? i would like to use the one you can fit in a 52mm guage or use a bigger one, but only after verifying i have an appropiate alternator, mine could well be different seeing as the van was bought used and was ex-london transport use. (dual batteries fitted, orange flashers on rear, tailgate door fitted), could well lead to a different alterantor for the dual batteries (doubt it but theres a chance)
also if you can mod mondeo clocks into transits ok what about escort clocks?
from mk5-mk7? would they work?
heres an example:
http://cgi.ebay.co.uk/FORD-ESCORT-MK5-D ... dZViewItem
it has the neat little car diagram on the left not seen that in the dash before.
Nothing Beats a Ford Transit!
stuntmaster
Postby motorwise » Sun Jun 10, 2007 11:34 pm
you need mondeo clocks they fit straight in the hole (mk5 and mk6) do a search there's loads on here about this :D
http://www.motorwise.net
motorwise
Postby MrMPuk » Sun Jun 10, 2007 11:35 pm
The reason Mondeo clocks fit is because they are the same as Transit clocks. Escort clocks are totally different.
Postby stuntmaster » Sun Jun 10, 2007 11:51 pm
yeh i knew that after seaching this thread, just wondered on the escort ones, well thats solved thanks guys!
what about the rev counter?
stuntmaster
Postby MrMPuk » Sun Jun 10, 2007 11:53 pm
stuntmaster wrote:yeh i knew that after seaching this thread, just wondered on the escort ones, well thats solved thanks guys!
Most the 52mm rev counters are for petrols and are much easier to fit. See if you can find one that runs off the alternator you might get it to work.
Postby stuntmaster » Mon Jun 11, 2007 12:19 pm
thanks will do!
i´ll have a lil experiment to see what i can do :)
stuntmaster
Postby Guy88 » Mon Jun 11, 2007 6:37 pm
Most rev counters will not work off the alternator :(
They also dont work with coil packs
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby stuntmaster » Mon Jun 11, 2007 7:28 pm
Hmmm in that case...... only thing i can really do is the mondeo clocks then.
how easy is it to fit one in a mk5? as in cosmetically i know the wiring is ok and i can run a wire from pin8 to the alternator if needed.
stuntmaster
Postby Guy88 » Mon Jun 11, 2007 8:46 pm
Direct swap 8)
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby MrMPuk » Mon Jun 11, 2007 8:50 pm
Guy88 wrote:Direct swap 8)
Which of course we have both already said.
Postby stuntmaster » Mon Jun 11, 2007 9:35 pm
superb, thats just what i wanted to hear!
awsome!
I guess the surround around the original clocks come off easily in order for me to remove them yeah?
thanks for the excellent advice!
stuntmaster
Postby stuartrobbie » Tue Jun 12, 2007 12:23 am
im looking at ebay and have found white dials for a mondeo 1993-2000, it says it simply slots over the original dials. ive read on here that mk5 and mk6s both can use mondeo clocks, does that mean the same clocks or would a mk5 need a mk5 mondeos clock, and a mk6 need a mk6 mondeos clock?
stuartrobbie
Postby Luke » Tue Jun 12, 2007 12:20 pm
are we on a mk6 mondeo allready :shock: mk1 mondeo clocks i think :D
Postby chadmat » Tue Jun 12, 2007 1:20 pm
You also need to check if they are cable or electric.
I have two sets of Modeo diesel clocks that are not needed.
£15 each plus post.
In a MK6 280 SWB semi hi!!!!
There you go! At last!
chadmat
Postby stuntmaster » Tue Jun 12, 2007 4:39 pm
are they cable versions?
stuntmaster
