DodgeRover wrote:There used to be kits available to turbo them, they may have used a different injection pump, you would probably have to make an exhaust manifold for the turbo unless one from a 2.5TDi could be made to fit. The rest should be pretty straight forwards but you would need to increase the amount of fuel the injection pump delivers to make best use of the extra air from the turbo.
Hello
I have been looking for the kit for some days now.
If you see it one day, will you tell me?
Would be great to turbo the engine. I have changed the timing belt, and will change all of the gaskets in the engine next week.
Plus I will take the valves out and clean them because one is hanging. Only done 6500 miles, so I think it will be bulletproof with a turbo after this
