Twin wheel alloys
Twin wheel alloys
Postby Guy88 » Sun May 15, 2016 10:01 pm
Alcoa are making them for the MK8 8) 8)
So these should also fit MK6 & 7
http://www.alcoa.com/alcoawheels/catalo ... hicles.pdf
wont be cheap thou, around £1500
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Re: Twin wheel alloys
Postby ned » Sun May 15, 2016 10:43 pm
Wonder if they do the duel style for a single wheel van quite like them, they look like truck alloys, don't like the single style. N
03 transit 125t280 2.0 tdci swb executive college blue 92 crewcab. Built in Belgium so deserves lots of love. 222,000 miles on the clock.
If you have a problem ask yourself what would BJT do :lol:
ned
Postby Guy88 » Sun May 15, 2016 10:55 pm
nedforceone wrote:Wonder if they do the duel style for a single wheel van quite like them, they look like truck alloys, don't like the single style. N
They are truck alloys, no paint or laquer, its got stuff impregnated into surface to make it stay shiney
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby ned » Sun May 15, 2016 11:04 pm
Thought I recognised the name from t&d mag, I want some don't think the duels would look right on my van :(. N
ned
Postby DodgeRover » Tue May 17, 2016 12:09 pm
Blimey, makes Euroliners look like a bargain
DodgeRover
Postby wojciech » Mon May 23, 2016 8:51 am
Guy88 wrote:Alcoa are making them for the MK8 8) 8)
Is it not necessary to move this information to viewtopic.php?f=13&t=14913 :?:
Transit alloys it is my hobby, so I will do it...
wojciech
Postby conrod » Sun May 29, 2016 6:07 am
I have emailed Alcoa and asked if they will make me a set of these but in 6x170 PCD for my Mk2. Will post the reply up when I get one :)
conrod
Postby Guy88 » Fri Jun 03, 2016 10:21 pm
conrod wrote:I have emailed Alcoa and asked if they will make me a set of these but in 6x170 PCD for my Mk2. Will post the reply up when I get one :)
Dont think alcoa would do a one off :(
adaptors maybe?
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby conrod » Sat Jun 04, 2016 10:15 am
adaptors maybe?
A week later and not even the courtesy of a reply! So you are probably right :( Adaptors would not work, as they would push the wheels out too far. Pity, as the Alcoa wheels would be spot on for offset and width on a Mk2! I did a lot of measuring, and looks like they would be good on the Mk2 with a 195 or 205/60x16 tyre.
conrod
Postby Guy88 » Sat Jun 04, 2016 10:17 am
adaptors maybe?
could hubs be swapped to later ones? then drill out wheel holes to suit?
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby conrod » Sat Jun 04, 2016 10:38 am
I don't know, it is possible I guess? When did the twin wheel axle change to 6x180? What was the PCD of the Mk5?
conrod
Postby Guy88 » Sun Jun 05, 2016 3:21 pm
conrod wrote:I don't know, it is possible I guess? When did the twin wheel axle change to 6x180? What was the PCD of the Mk5?
MK5 is 6x180 with 24mm studs
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby conrod » Tue Jun 07, 2016 5:50 am
thanks, that helps :)
I am now considering fitting a Mk7 rear axle to mine, narrowed to suit. That would give me disc brakes, a much better ratio, and 6x180 :) Will look at fitting Mk5-7 front discs to the Mk2 front axle. Can't redrill the existing front hubs as there is not enough material outside the studs to make 6x180.
conrod
Postby oldyellar » Wed Jun 08, 2016 9:00 pm
Mk8 wheels do not fit on the inside rear I put 6 on my mk7 and it wouldn't budge when I went to drive it I just put mk7 wheels on the inside and 4 mk8 wheels on the outside
Why wasn't Rome built in a day?
Becuase I wasn't the Gaffer!
oldyellar
Postby conrod » Thu Jun 09, 2016 12:09 am
all very interesting! So obviously some variations in offset for the later model wheels. Looks like I need to research a bit more, and have the wheels I intend to use here, as well as the rear axle, before cutting/narrowing it to suit.
conrod
croncroncron
