Q: MkIV axles on MkII
Postby Injection » Sun Sep 25, 2016 8:43 am
So I have 2 Transits:
First one's MkII '81 100L Kombi 2.0 57kW.
The second, the donor, is a '93 MkIV 100L 2.5TD 63kW.
I am going to swap the diesel engine into MkII. Also I wonder how well MkIV-s axles fit to it. Just beacause I'm guessing that they're a little more modern and parts are easier and cheaper to get.
As MkII is still going to be transported to me, I haven't had a closer look at it's axles.
What are either axle's pros and cons? Is the swap worth it?
Injection
Re: Q: MkIV axles on MkII
Postby Luke » Sun Sep 25, 2016 10:39 am
the axle will fit but without the flared wheel arches you will only just fit the wheels under
but as for modern parts they arn't really much different - the actual cw&p is intechangable but the entire diff is not as the half shafts are different sizes
i swapped a mk5 axle onto my mk1 lwb but i only did it to get rid of the twin rear wheels and the high diff ratio
this is mine
if you do fit the axle all you'll need to do is turn round the shock mounts as they face the opposite way mk4 and mk5
Postby Injection » Sun Sep 25, 2016 11:15 am
Luke wrote:the axle will fit but without the flared wheel arches you will only just fit the wheels under
this is mine
Sounds good. What can you tell about front axle? I know, MkIV has steering rack, I suppose that MkII has box type still.
Injection
Postby Luke » Sun Sep 25, 2016 11:30 am
yes mk4/5 have a rack and mk2 has a box - not an easy swap but it is possable i have done it twice and a few other have too
when it's done it is much better to drive as i had a cosworth engine fitted - but with my mk1 lwb i have kept the beam axle and fitted a power box - the van isnt as quick so its ok
viewtopic.php?f=13&t=65
Postby Injection » Mon Sep 26, 2016 5:42 pm
Luke wrote:yes mk4/5 have a rack and mk2 has a box - not an easy swap but it is possable i have done it twice and a few other have too
I guess, I'm going that way too then.
Great thread, thanks for your reference!
Injection
Postby Injection » Mon Sep 26, 2016 6:47 pm
Luke wrote:...this is mine
Really nice flares you have on it. What are they exactly?
Injection
Postby Luke » Mon Sep 26, 2016 7:53 pm
they are standard twin wheel mk1 arches :D
i think if you got hold of a pair they would bolt up to yours :idea:
Postby Luke » Mon Sep 26, 2016 7:57 pm
full build thread is here :arrow: viewtopic.php?f=27&t=34477
