Anybody tried an LED Head lamp bulb kit
Postby paulrichardson » Mon Jul 10, 2017 4:27 pm
Hi Guys,
Not sure if this counts as a mod?
I've noticed quite a few LED headlamp bulb conversion kits appearing on ebay and Amazon.
I wondered if anyone has tried on, and if they are any good.
The reviews on Amazon sound positive.
Regards,
Paul
paulrichardson
Re: Anybody tried an LED Head lamp bulb kit
Postby boltondigger » Mon Jul 10, 2017 5:20 pm
search button is your freind :D
Had a rusty old 58 plate 85 ps swb.180 thou .most reliable bus ive ever had
12 plate limited 125bhp 260 that got nicked :shock: :shock:
2016 connect poverty spec
boltondigger
Postby Mike » Mon Jul 10, 2017 5:26 pm
boltondigger wrote:search button is your freind :D
:lol:
Mike
Wind up merchant!
Postby paulrichardson » Mon Jul 10, 2017 5:51 pm
Tried that but found nothing!
paulrichardson
Postby richgold » Mon Jul 10, 2017 6:32 pm
I've had some h4 with an inline controller which werent bad, like these
Nighteye 80W 12000LM H4/HB2/9003 LED Headlight Light Bulbs Hi/Low Replace XENON
£ 43.99 - SOLD (fixed price)
Ended Tue Dec 26th  6:38am GMT
Seller: neverland-gbp
But dont get the h4 bulb-type lights like these below as you'll soon wish you hadnt.
2X H4 Xenon White 120 LED 3528 SMD Fog Headlight Hi/Lo Beam Bulb Light Lamp 12V
Volkswagen Crafter 136 LWB 2016 back in white and staying that way!.
Vauxhall Nova GTE 1300 1988 in Royal Blue - My new toy!
Transit 115 Jumbo 2010 - SOLD!
Audi TT 225 Roadster - SOLD!
Mercedes Sprinter 311 LWB 2004 - SOLD!
richgold
Postby paulrichardson » Mon Jul 10, 2017 8:27 pm
richgold wrote:I've had some h4 with an inline controller which werent bad, like these
Hi, thanks for the info, couple of questions if you don't mind.
1) Was the fitting easy?
2) Are they loads brighter?
3) Have they passed an MOT yet.
Regards,
Paul
paulrichardson
Postby richgold » Wed Jul 19, 2017 10:31 pm
Fitting was easy.
They werent much brighter but it was a crisper sharper light if that makes any sense. A better colour than yellow thats for sure.
Take them out for the mot if you're worried. Fitting is around 5 mins a bulb and that includes taking the headlight out.
richgold
Postby gatecrasha » Fri Aug 11, 2017 10:29 am
Off topic.
Ive recently fitted the latest type HID kit.
Results are brilliant (excuse the pun)
All in one plug n play hid bulbs with in built ballasts
No seperate ballast to mount etc.
Just a bulb with ballast on its back end and a small lead which plugs direct into original bulb holder.
As yet ive had no one on coming toward me flash because of being blinded etc.
Only downside is the ballast on back when fitting
I found best way to fit is to remove headlight unit to ensure bulb is seated in headlight correctly and to make aure bulb retaining clip is fitted properly as ballast can make it tricky to fit with headlight in place
gatecrasha
Postby Mike » Sat Aug 12, 2017 7:41 pm
gatecrasha wrote:Off topic.
Must be in a MK6 then?
Mike
Wind up merchant!
Postby Thequeenscheese » Sat Aug 12, 2017 8:51 pm
I've had oral night breakers for years now (in fact the same bulbs came out of my freelander, into my navara, now in the transit) -I don't think you can beat them for vision at night without hids etc..
2.2 tdci T280
Thequeenscheese
