probably a really really bad idea....but...!
Postby gordyshreds » Mon Jul 23, 2007 9:46 am
what if on your van, if all the bodywork was clean and dry etc etc you sprayed on a clear lacquer mixed with a metalflake. would this look utter crap of possibly work????
gordyshreds
Postby transitgeoff » Mon Jul 23, 2007 10:20 am
it will just flake off unless you prep the surface :)
transitgeoff
Postby jamieo » Mon Jul 23, 2007 10:39 am
As transitgeoff said it will just flake off unless you prep the surface, it could look cool 8) depending on what colour your van is now and what colour metalflake your planning on using.
I think you need to give a few more details or even post a couple of pics of your van and some of the colour of metalflake that your thinking of using.
Edit: One idea that you could try before painting your van would be to get an old body panel, paint it the same colour as your van then spray on the metalflake so you can see what it looks like yourself. :)
Blue 1998 Ford transit 2.5di 70ps 120 swb low roof Mk5 with 5 seats. 1.5 turns on pump, egr butterfly removed and a stainless steel Urban X funnel air filter fitted. Now happily burning SVO.
jamieo
