Punto443 wrote:If you look under the mk7 rear end you will see the axle and the leaf springs are bolted to the top of the axle.
By flipping it, it means moving the axle to sitting on top of the springs, so they run under the axle.
However, it means that the entire van weight is supported only by the u-bolts that secure the springs.
This is probably fine on a car etc, but I’d be hesitant to do it on a commercial vehicle.
IMO, far better to have the rear springs reprofiled or new lowered ones fitted.
But again, only my opinion.
