MK7 Dash Backlight Colour Change
Postby NoisyBoy » Thu Dec 05, 2019 8:05 pm
Has anyone ever managed to change that hideous green backlight colour for something else? In my opinion the green looks really old school, so I am thinking about white or red. Already have an idea how to replace light behind the heater /AC, but wondering about the rest (speedometer & clock, headlight) - any advice mostly welcome, many thanks!
NoisyBoy
Re: MK7 Dash Backlight Colour Change
Postby loot » Thu Dec 05, 2019 9:59 pm
Been there :D
Smd leds will do everywhere, there's posts on it somewhere. The heater is the hardest as you need to gently rub away the green paint.
I like blue.
Ids map here
loot
Postby martynx » Tue Dec 24, 2019 11:23 pm
Use a hot air station to remove the old LED's , i use a an "Atten 858D+" chinese special. The LED's have a small cutout on them , that indicates the polarity. They aren't all fitted one way. I've only done white for the dials , & red for the LCD, pleased with the results although the dimmer function doesn't work well, becomes very un-linear - May need a resistor adding to its circuit,
for egr/dpf deletes, power tuning, updates,cloning,speed limiter removal,cruise control, euro 3/4/5/6 limiters & key's !
martynx
Postby loot » Tue Dec 24, 2019 11:25 pm
Mine dim ok 8)
I have a similar station lol, the leds benefit from a quick heat or they melt :lol:
Ids map here
loot
Postby martynx » Tue Dec 24, 2019 11:30 pm
loot wrote:Mine dim ok 8)
Yes they melt easy for sure ;) the replacements i was given give the correct colour at a slightly different voltage than the original's but saying that maybe my dimmer pot is actually faulty :lol: :D
martynx
Postby Punto443 » Wed Dec 25, 2019 12:30 am
Tried red, blue, white :D
Even inverted the lcd so that letters lit up instead of the background, and radio display.
Just a bit fiddly :wink:
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
