Pictures of all available correct size pcd Transit alloys
Re: Pictures of all available correct size pcd Transit alloy
Postby wojciech » Tue Feb 04, 2020 9:43 pm
Dezent, model: K7984, size - 7Jx16", PCD 5x160mm, ET - 50mm, CB 65.1 mm, load 1.050 kg = 2.315 lbs, finishing: Silver
Known also as DEVINO STAR, size 6.5Jx15" and 7.0Jx16"
This model has 6 spokes and five sockets, but in this case it looks really as.. designer butchery. Massacre :cry:
wojciech
Postby wojciech » Tue Feb 04, 2020 9:46 pm
Eta Beta, model Atria, size 6.5J x 16", PCD 5 x 160 mm, CB 65.1 mm, load 1.150 kg = 2.535 lbs, finishing: Silver
wojciech
Postby wojciech » Tue Feb 04, 2020 9:52 pm
Autec , model Type Q - Quantro , size 6,5J x 16" ET 55/60 mm and 7,0J x 17" ET 54/55 mm, PCD 5 x 160 mm, CB 65,1 mm, load 1.150 kg = 2.235 lbs, finishing: Brilliant silver oraz Black polished
wojciech
Postby wojciech » Wed Feb 05, 2020 7:25 pm
RRW/JWL, model RR6-V, size 7.5J x 17", ET 30/50 mm, backspacing: 5.43" (+30 offset) / 6.22" (+50 offset), PCD 5 x 160 mm, load rating: 1.655kg/3650 lbs (heavy duty load rating)
wojciech
Postby wojciech » Wed Feb 05, 2020 7:28 pm
RRW/JWL, model RR6-S, size 7.5J x 17", ET 30/50 mm, backspacing: 5.43" (+30 offset) / 6.22" (+50 offset), PCD 5 x 160 mm, load rating: 1.134kg/2.500lbs
wojciech
Postby wojciech » Wed Feb 05, 2020 7:30 pm
RRW/JWL, model RR5-V, size 7.5J x 17", ET 30/50 mm, backspacing: 5.43" (+30 offset) / 6.22" (+50 offset), PCD 5 x 160 mm, load rating: 1.655kg/3650 lbs (heavy duty load rating)
wojciech
Postby wojciech » Wed Feb 05, 2020 7:35 pm
MotionR, model VS1, size 8Jx18" and 8Jx20", PCD 5 x160 mm, ET 50 mm, CB 65.1 mm, 3x colours available: Hyper Silver, Satin Gunmetal and Satin Black, load rating: 800 kg/1.764 lbs per wheel.
Their spirit of design is similar to first in history Transits alloys - cult Ronal RS for Transit Mk3 1986 - 1991 (size 7J x 14"). Very nice, old school project...
One fault: it's really hard to keep clean.
wojciech
Postby wojciech » Wed Feb 05, 2020 7:36 pm
MotionR, model VS1,
wojciech
Postby wojciech » Wed Feb 05, 2020 8:02 pm
OEM alloys for Transit Custom Sport, size 7.5Jx18", ET 56 mm, PCD 5 x 160 mm, mounted with tires 235/50R18. With this alloys van has lowered series from 310 to 290
wojciech
Postby wojciech » Wed Feb 05, 2020 8:09 pm
MAK, model Load 5, size 6.5J x 15", ET 58 mm or 6.5J x 16", ET 60 mm or 7.0J x 17", ET 55 mm, PCD 5 x 160 mm, finishing: Silver lub Ice Black, axle load index of 5,950 lbs (2,700 kg)
wojciech
Postby wojciech » Wed Feb 05, 2020 8:13 pm
MAK, model Stone 5,
size:
6.5J x 15" ET58 mm
6.5J x 16 ET 60 mm
7.0J x 17 ET 60 mm
7.5J x 17 ET 52 mm
7.5J x 18 ET 50 mm
PCD 5 x 160 mm, load 2,535 lbs (1,150 kg), finishing: Silver, Gloss Black, Black Mirror
wojciech
Postby wojciech » Wed Feb 05, 2020 8:15 pm
MAK, model Stone 5
wojciech
Postby wojciech » Wed Feb 05, 2020 8:18 pm
Ford OEM alloys for Transit Custom Sport/Tourneo (2016/2017), size 7.0J x 17", ET 55 mm, PCD 5 x 160 mm.
wojciech
Postby wojciech » Wed Feb 05, 2020 8:22 pm
Unknown producer, "Made in TR" (Turkey?), size 7.0J x 17", ET 55 mm, PCD 5 x 160 mm
On wheel is located certification mark of JWL Standard (Japan Light Alloy Wheel standard).
wojciech
Postby wojciech » Wed Feb 05, 2020 8:36 pm
OEM Transit Custom alloys 2012 - 2019, size 6,5"Jx16", ET 60 mm
wojciech
