MK7 front centre bumper plastic bit
Postby ossie cossie » Sat Apr 25, 2020 1:07 pm
Has anyone removed the large ford badge from the gray front bumper plastic bit on aMK7, if so can you explain how and put up pics of how it was done?
ossie cossie
Re: MK7 front centre bumper plastic bit
Postby Punto443 » Sat Apr 25, 2020 2:37 pm
It's held on from the rear with 2 ring clip things, then it can be prized of, there's a bit of double sided tape stuff on it.
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Postby ossie cossie » Sat Apr 25, 2020 2:52 pm
once it comes of is it then easy to make it look like it has never had one by cutting the plastic bars that are left?
ossie cossie
Postby ned » Sat Apr 25, 2020 3:01 pm
I have seen it done a few times, I recall someone cut the section with the oval bit out and grafted in a straight piece from another bumper centre
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
