ROLLER PAINTING MY VAN ?
Postby carlburt78 » Fri Jun 05, 2020 8:12 pm
Hi I have a mk7 2008 Transit that I use for courier work , I have just spent some time sorting the rust bubbles ect and bought some Frozen white spray as this is what the van had stamped under the bonnet , I think the previous owner repeated the van as the colour is not matching the panels , to be honest the paintwork is rather dull and scratched and could do with a makeover, I dont really want to pay out more than the Van's worth on a respray and was wandering if a roller paint job is any good as I've heard of it being done before but never seen one, have any of you guys ever done this ? Foes the finish look ok ? What paint is best to use ? Many thanks Carl
carlburt78
Re: ROLLER PAINTING MY VAN ?
Postby Chug » Fri Jun 05, 2020 8:26 pm
I've rollered a few cheapo motors with good results and a definite improvement on what they were before, but If you roller use a mini roller and make sure you get good quality rollers and not cheap ones, they aren't that expensive really and it makes the difference between a good job or not, I don't think the paint matters too much, I've used all sorts.
But the prep is the key, a badly prepped surface will never look good whether sprayed or rollered.
Like these https://www.amazon.co.uk/Harris-Taskmas ... B00F3ZLFMY
Chug
Postby carlburt78 » Fri Jun 05, 2020 9:02 pm
Chuggy wrote:I've rollered a few cheapo motors with good results and a definite improvement on what they were before, but If you roller use a mini roller and make sure you get good quality rollers and not cheap ones, they aren't that expensive really and it makes the difference between a good job or not, I don't think the paint matters too much, I've used all sorts.
Thanks for the advice , I love my van but she really needs a makeover, you say any paint , but I assume it has to be paint specifically for metal ? My van is white so will probably want to keep it white
carlburt78
Postby Chug » Fri Jun 05, 2020 9:46 pm
yeah, you seemed savvy enough that I didn't need to say "not magnolia vinyl silk emulsion" :wink:
Chug
Postby bambi mk 1 » Fri Jun 05, 2020 9:57 pm
Chuggy wrote:yeah, you seemed savvy enough that I didn't need to say "not magnolia vinyl silk emulsion" :wink:
Snowcem would be a good match :lol:
bambi mk 1
Postby Chug » Fri Jun 05, 2020 10:26 pm
Yeah I've used matt black smooth masonry paint on bumpers and wheel arch covers, looks good and wears well. :lol:
Chug
Postby ned » Fri Jun 05, 2020 10:27 pm
Don't use them shitty cheap foam rollers they'll just put air bubbles in the paint, Toolstation do some pro Dec ice fusion ones that are good or Wickes do some orange flock mini roller sleeves
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby carlburt78 » Fri Jun 05, 2020 11:27 pm
Ha ha , it was a silly question :lol: just had to rule out the Magnolia
carlburt78
Postby carlburt78 » Fri Jun 05, 2020 11:30 pm
ned wrote:Don't use them shitty cheap foam rollers they'll just put air bubbles in the paint, Toolstation do some pro Dec ice fusion ones that are good or Wickes do some orange flock mini roller sleeves
Thanks I will look at getting some decent ones , roller paint job it is then :D
carlburt78
Postby carlburt78 » Fri Jun 05, 2020 11:31 pm
What do I need to do the cutting in ? :lol: :lol: :lol:
carlburt78
Postby ned » Fri Jun 05, 2020 11:35 pm
The bus companies roller paint the busses in company colours, rustolium do some good paint, it's not cheap though, as said the finish all depends on the preparation.
For the cutting in use a good quality brush
ned
Postby dumper » Sat Jun 06, 2020 7:59 am
At work they started putting some lacquer in the top coat to give it a shine and stop it getting dull after a week or so .
They brush paint/roller them so they don’t have to have all the health and safety rules that spraying has when they get a new bus it’s sprayed by the manufacturer some 06 plate ones are still on original paint but the hand painted ones need doing regularly.
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby bortaf » Sat Jun 06, 2020 2:40 pm
I've only really used NATO paint but i found the long hair type rollers left a better finnish than the foam ones? left a smoother surface and less bubbles, also dont do it on a hot day, the paint needs time to settle and flow before it drys, also dont do it on a cold day :lol: warm day in the shade i found best or indoors in controled sun and heat if possable ?the bonnet on my ambulance was done in direct sun and it's very streaky, you can see the roller lines as it dried too quick to allow the paint to flow into each roller run.
P100 came out fine, the ambulance is stripey cos it was painted in the sun and dried to quickly
Current fleet
Mk7 transit ambulance
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
Postby carlburt78 » Sat Jun 06, 2020 6:33 pm
So about 9.30 in the morning on a dry day :D thanks for the advice ,
carlburt78
Postby Scottyp86 » Sun Aug 16, 2020 8:31 pm
Any pictures of roller paint jobs. Thinking of doing my mk7 is olive drab.
Scottyp86
