Guess which bits.
Guess which bits.
Postby sportscott » Mon Sep 24, 2007 9:42 pm
The top one is correct and fits the lower one just needs a little more hammer. It fits mk3,4,5.
Transit the everyday mans van....
sportscott
Postby BigNeil » Mon Sep 24, 2007 10:28 pm
is it for the radio ?
BigNeil
Postby sportscott » Mon Sep 24, 2007 10:33 pm
no, it's a repair section :lol:
sportscott
Postby snap-on » Mon Sep 24, 2007 11:17 pm
rear underbody?
Dave
snap-on
Postby sus » Mon Sep 24, 2007 11:19 pm
oojamaflip left side of course
connect 110T200 with aircon
sus
Postby sportscott » Tue Sep 25, 2007 4:13 pm
snap-on wrote:rear underbody?
Yes your right it's the end of the outriggers, which have completely rotted away on my mk3 the most frightening bit is on my my mk5 have noticed it's a little wet inside the load floor around the wheel arch above the same place despite waxing it :? got to all I can in those areas.
sportscott
Postby snap-on » Tue Sep 25, 2007 5:05 pm
Good luck mate. I hate welding the underbody get burnt to death :lol:
Dave
snap-on
Postby sportscott » Tue Sep 25, 2007 8:09 pm
snap-on wrote:Good luck mate. I hate welding the underbody get burnt to death :lol:
I'm using gasless wire, which can be burny at best of times but intend on doing as little full seam welding as possible and try to fold and beat as much of the rear corner/outrigger/springhanger/floor as I can out of one piece :idea:
sportscott
Postby sportscott » Tue Sep 25, 2007 8:43 pm
This is my first attempt template just to gauge the measurents and with no more than a tape measure came to a guesstimate of 19 x 19 cm with the triangular bit 3 x 5 cm, which was logically correct :o I need to leave longer tabs on the floor section to take in four surfaces excluding outrigger and think it's possible to pre-weld the whole thing, hold it up there and spot/weld it in . I have a boarded out Van, the ply is 19mm, hardwood and glued in so no access from above.
sportscott
Postby snap-on » Tue Sep 25, 2007 8:50 pm
Looks good what gauge metal are you using?
Dave
snap-on
Postby sportscott » Tue Sep 25, 2007 9:18 pm
snap-on wrote:Looks good what gauge metal are you using?
1mm I Think but without measuring it but is about the same thickness as original and is phosphor zinc coated.
sportscott
Postby steved » Wed Sep 26, 2007 9:41 pm
:shock: nasty fumes off galv! usualy spits bad too.. one to avoid being underneath! :? welded the o/s rear springhanger/ outrigger the other week :( i used steel cut from a knackered bonnet.. made sure everything was nice and clean.. and still looked like a burns victim afterwards :( :( :( not much fun.. good luck bud :D
steved
Postby sportscott » Thu Sep 27, 2007 5:34 pm
steved wrote::shock: nasty fumes off galv! usualy spits bad too.. one to avoid being underneath! :? welded the o/s rear springhanger/ outrigger the other week :( i used steel cut from a knackered bonnet.. made sure everything was nice and clean.. and still looked like a burns victim afterwards :( :( :( not much fun.. good luck bud :D
Galvinised and phosphoric zinc are different but it's still toxic and must be cleaned off. I'm going to clean everything up first as best I can. Still playing with paper at the moment and this is how it's taking shape the proportions are not correct as it's only a model but have seen that the corner can be improved, that is if I leave more on the end a sort of fishtail then I can get it to meet the two other sides when folded underneath. The plan is to prefab this then weld it in and I'll probably cut out some of the ply floor to get acces.
I'm a black belt in origami :lol:
And the beauty is it's the same for the otherside :D
sportscott
