MK2 TRANSIT 2.9 COSSY BOA
Postby Twostroke » Sun Apr 25, 2021 9:32 am
Hi all ,
We are building a MK2 transit with 2.9 BOA engine.
Question is would the type 9 hold or I will need mt75.
I have a guy with diesel mt75 and a adaptor plate but not sure what is the best way.
I also have Sierra V6 type 9 and was wondering if I can swap the gear selector from a transit type 9 so. It stays forward behind the bell housing?
Thanks a lot
Twostroke
Re: MK2 TRANSIT 2.9 COSSY BOA
Postby Chris21r » Sun Apr 25, 2021 10:51 am
Type 9 won't last. The type 9 in the transit is unique to it. Sane as the MT75. Gear lever can't be swapped.
Fit the adaptor plate and flywheel onto the MT75.
Chris21r
Postby Boffin » Mon Aug 09, 2021 8:35 pm
Hi there, as Chris21r says use the mt75. I had the same set up your on about using in my mk2 about 8 years ago. Went pretty well. Got a 15.9 at santa pod with that set up.
Best of luck with it. ;)
Boffin
Postby Luke » Mon Aug 09, 2021 9:37 pm
Ford had both boxes available and went to the trouble of making an adaptor plate for the MT75 for the standard 2.9V6 so i would think the 24v would be best with it :)
