Winch
Winch
Postby Guy88 » Mon Dec 03, 2007 12:44 am
I am thinking of mounting a winch on the rear of my MK5 SWB.
Where would be the best place to mount it to. I got a tovbar so could adapt that
It will be a 4 tonner :twisted:
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Re: Winch
Postby pykee » Sun Dec 30, 2007 11:09 pm
I have seen winches that mount on to a tow ball and can be removed when not needed so it wont go missing i think it was machine mart that were selling them :D
pykee
Re: Winch
Postby fastmower » Sun Dec 30, 2007 11:19 pm
The winch on the County mounts in between the towing bracket side arms. Originally would have been two parts I think, but the tow bracket and winch frame have been welded together to form one (fookin heavy!) unit.
If it's any help I can take some pics and some measurements to give you an idea of whether you'd have the room to get it under yours?
Cheers mate,
Andy
From four vans to two :-(
1997 Mk5 County Transit 4x4
2003 Mk6 ex RAC 330 SWB
fastmower
Re: Winch
Postby fastmower » Tue Jan 01, 2008 7:42 pm
Took a few pics and got the tape out!
The "arms" of the towing bracket that can be seen in the first pic are 740mm apart.
The holes for the mounting bolts are approx. 905mm between centres
From the top surface of the mounting plates to the lowest part of the winch is 360mm
The winch frame is mounted between the two sides of the towing bracket, but uses the same four mounting holes in the chassis. The supports for the rear top steps are welded to the winch side frames. The plate on the left in the second pic is the mounting for the isolator and the remote plug.
Dunno if this will be any help - but if you need any more pics or measurements I'll be happy to oblige.
Cheers for now,
Andy
fastmower
