Pollenfilter conversion
Postby Stevelien » Wed Sep 18, 2024 10:47 am
If you want to make a pollen filter on an MK6 and don't have a (rare) correct unit from the factory: cut off the end of the existing unit and install the filter, they are the same units only sealed shut and without a removable shut-off valve cover. The filter will fit exactly. I have currently used temporary duck tape as a closure, but this winter I will make a better closure. It works perfectly!
Stevelien
