AUX IN [Help]
AUX IN [Help]
Postby KiloKilo » Tue Jan 15, 2008 6:15 pm
Trying to fit an AUX IN in my Mk7.
Installed an old 6000CD unit from Jan 2004 as a temporary radio and decided to fit the aux in as found in the Fiesta / Fusion models.
Was pointed to the fact that the space for a 12V socket at the passenger side would be a great place for it.
So I took out the dummy plastic disk. The way it is kept in place is by two plastic clips. Unfortunately these clips are a bit big.
So if I drill a hole for the AUX IN the whole construction of the clips will go. So then the question; How do I make the newly constructed piece stay in the socket?
KiloKilo
Re: AUX IN [Help]
Postby MrMPuk » Tue Jan 15, 2008 7:14 pm
Looks like the Fiesta one is different then.
Re: AUX IN [Help]
Postby KiloKilo » Tue Jan 15, 2008 7:17 pm
MrMPuk wrote:Looks like the Fiesta one is different then.
Not quite. With the Fiesta / Fusion the idea is to drill a hole in the dash near the cup holder. I could drill a hole anywhere. But it is saver to use the dummy plastic cap instead on drilling a hole in the dash. Replacing the dummy will be cheaper then the dash.
KiloKilo
Re: AUX IN [Help]
Postby MrMPuk » Tue Jan 15, 2008 7:19 pm
I say it looks different because the Transit one just replaces the blank.
Re: AUX IN [Help]
Postby KiloKilo » Tue Jan 15, 2008 7:24 pm
MrMPuk wrote:I say it looks different because the Transit one just replaces the blank.
..... I am beginning to get frustrated with the dealer again. They couldn't find an AUX IN for the Transit. So that's why I took the Fiesta / Fusion one....
Anybody got the partnumber for the Transit one?
KiloKilo
Re: AUX IN [Help]
Postby cha10 » Thu Jan 17, 2008 1:04 am
havent got a part number but mine came alreay fitted in the cubby box above the speedo / dials etc etc it was done free of charge too :D
cha10
Re: AUX IN [Help]
Postby KiloKilo » Thu Jan 17, 2008 12:15 pm
cha10 wrote:havent got a part number but mine came alreay fitted in the cubby box above the speedo / dials etc etc it was done free of charge too :D
Do you have a picture/photo of it maybe?
KiloKilo
Re: AUX IN [Help]
Postby KiloKilo » Thu Jan 17, 2008 2:40 pm
Just back from Ford. They had found an AUX IN for the Transit. I went today to pick it up. Turned out to be the exact same as the Fusion / Fiesta one just in a lighter grey colour. Talked to them about a possible solution. We had a look thru the Ford Parts system and nothing really came up. Even the AUX IN which they ordered was mentioned in the system as being a Heater Control Switch..... :?
I know that there was a mention of standard fitting AUX IN into the Mk7 from October 2007. Anybody any idea where they fit the AUX IN?
Again any photo or partnumber is welcome.
KiloKilo
Re: AUX IN [Help]
Postby mhpete » Thu Jan 17, 2008 8:06 pm
I just carefully drilled a hole in the blanking plug till the aux plug would fit then super glued the whole lot in position.
Pete
mhpete
Re: AUX IN [Help]
Postby Azer van man » Sat Jan 19, 2008 5:30 pm
In the Transits being made now they are fitting it in the passenger glovebox where the cigerette lighter would go :wink:
Azer van man
Re: AUX IN [Help]
Postby MrMPuk » Sat Jan 19, 2008 6:03 pm
Azer van man wrote:In the Transits being made now they are fitting it in the passenger glovebox where the cigerette lighter would go :wink:
He says that in the top post, but what he's saying is it's not the correct size for the hole!
Re: AUX IN [Help]
Postby KiloKilo » Sat Jan 19, 2008 7:26 pm
If you happen to have a photo of it or the part number so I can show to the local Ford dealer I would very grateful.
KiloKilo
Re: AUX IN [Help]
Postby Azer van man » Sat Jan 19, 2008 7:48 pm
Hi mate go on ebay and enter this number on "advanced search" https://www.ebay.co.uk/itm/120210406592&seller=&toolid=10018&92857072" rel="nofollow">https://www.ebay.co.uk/itm/https://www.ebay.co.uk/itm/120210406592 thats the same one as i bought but i also bought a 3.5 mm jack lead as the Ford lead is not that long hope this may help i can take some pics of mine tomorrow and send you if thats any help :wink:
Azer van man
Re: AUX IN [Help]
Postby MrMPuk » Sat Jan 19, 2008 7:59 pm
Azer van man wrote:Hi mate go on ebay and enter this number on "advanced search" https://www.ebay.co.uk/itm/120210406592&seller=&toolid=10018&92857072" rel="nofollow">https://www.ebay.co.uk/itm/https://www.ebay.co.uk/itm/120210406592 thats the same one as i bought but i also bought a 3.5 mm jack lead as the Ford lead is not that long hope this may help i can take some pics of mine tomorrow and send you if thats any help :wink:
That's the same one he has already.
Re: AUX IN [Help]
Postby Azer van man » Sat Jan 19, 2008 9:08 pm
Thats what i thought but if you look at the picture you can see the part number,when i bought mine it was the only one Ford's done at the time,I don't know if its changed at all since they've started fitting it as standard :?
Azer van man
