what gearbox will fit this engine???
Postby dangeeeeerousss » Wed Feb 13, 2008 6:55 pm
hi
ive got a rover 2.0 injection turbo 16v twin cam with dump valve fitted
and i want to know what gearbox will fit it to convert to rear wheel drive in a transit????
dangeeeeerousss
Re: what gearbox will fit this engine???
Postby Luke » Wed Feb 13, 2008 7:01 pm
is it a T16 out of a 820 or 220 sort of thing :D
Postby Gavin » Wed Feb 13, 2008 8:05 pm
found this info on the mg rover forums
Anyways, what has been said is correct (as usual, good quality gen on this board!). You can use an LT77, ex SD1, or a new 2wd R380. Heck, you can even use a 4x4 one if you convert it to 2wd, but it's hardly worth it...
Bellhousing is 2000 SD1, LDV400 2.0, or Sherpa 2.0 diesel. The Disco bellhousing is meant to mate up to a big clutch housing on the back of the engine, and is a different shape (I have a bellhousing I bought here when I was doing my first RWD conversion )
As for the Ford Type 9, well, there is *supposedly* a bellhousing available
Gavin
Postby Luke » Wed Feb 13, 2008 9:06 pm
Gavin wrote:As for the Ford Type 9, well, there is *supposedly* a bellhousing available
is there :idea: ive got one in my mk1 escort i made the bellhousing from a type9 xr4 back half and a rover front half - welded together :D
also there is 'supposed' to be an adapterplate for an mt75 but i couldnt get hold of one - and measuring it up i cant see how it would have worked :|
good engine tho - shifts in the rover and used to be for peanuts :D
Postby dangeeeeerousss » Thu Feb 14, 2008 12:28 am
thanks for the info guys the engine is in a rover 620
dangeeeeerousss
Postby rover » Thu Feb 14, 2008 10:02 am
Get a sheet of card dave, then paint the maunting face of the original gearbox bellhousing and press the card against it while wet, then cut out the shape and take it to the scrappy with you and try it against different gearboxes :idea:
If you are looking for an auto I would think the old Rover favourite- BW boxes would be close, unless you can find a Jap RWD box :?
Rover.
rover
Postby Luke » Thu Feb 14, 2008 1:25 pm
dangeeeeerousss wrote:thanks for the info guys the engine is in a rover 620
ive been told - not sure how true it is that the 620's have the honda engines in! although i could swear ive seen a T16 in one :D - so mabe they had both :? but .................. make sure its not a honda one cos if it is it spins the other way :(
Postby bazw » Thu Feb 14, 2008 1:38 pm
lol it would be like an Italian tank with that in
1 forward and 5 reverse gears :D :D :D :D
350L Series 56 plate
2.4 duratorq 115 ps
A.R. 4.27
bazw
Postby Luke » Thu Feb 14, 2008 5:53 pm
bazw wrote:lol it would be like an Italian tank with that in
like that :lol: :lol: :lol:
Postby dangeeeeerousss » Thu Feb 14, 2008 9:16 pm
hi thanks for the info guys the only reason i asked is. Im thinking of doin another custom transit if i come across 1 cheap enough as well as the 1 i have.
dangeeeeerousss
Postby dangeeeeerousss » Sun Feb 24, 2008 3:15 am
i may just have found the van for this engine
dangeeeeerousss
Postby Luke » Sun Feb 24, 2008 10:25 am
another problem with it is the dizzy sticks out of the back :( when i fitted it in the escort i cut away the bulkhead and as i had no heater it wasnt a problem - not sure where it would sit in the van tho :? also my escort wasnt exactly mint :lol:
Postby dangeeeeerousss » Sun Feb 24, 2008 11:13 am
dont worry i aint gonna even think of messing that art work up i have a few subtle ideas in mind already and i havent picked it up yet but there all working round the art work :wink: :wink:
dangeeeeerousss
Postby Luke » Sun Feb 24, 2008 11:26 am
i was looking through my escort pics to see if i could find some to show where it sits compaired to the pinto as i removed a pinto to fit the T16 but i only have 1 as it was before i had a camera, and it doesnt show the back of the engine :|
