Transit audio system
Postby akuhenrikkorhonen » Fri May 16, 2008 3:51 am
Greetings from Finland !
I going to fit some speakers in it, but have no idea how to...help me please
Last edited by akuhenrikkorhonen on Sun Jun 29, 2008 1:56 pm, edited 2 times in total.
akuhenrikkorhonen
Re: trying to fit new speakers...
Postby spudmab » Fri May 16, 2008 11:20 am
hello,
it depens where you want the speakers, they normally live behind the door cards, have a search and there is proberly a post on how to remove the door cards,
good luck remember to take some pics,
spudmab
Postby zaphod79 » Sat May 17, 2008 9:14 am
I had some issues with this, my post became very helpful, hope it is to you
viewtopic.php?f=4&t=15135
Ford Transit 2.4 TD 00(X) LWB med roof 350
See my camper van progress so far viewtopic.php?f=58&t=45397&p=404672#p404672
zaphod79
Fitted new speakers
Postby akuhenrikkorhonen » Fri May 23, 2008 3:24 am
I had no problems removing those door cards, it was actually quite easy...
I replaced original speakers with 6,5" component speakers. Speakers didn't fit straight away, so I made an adapter from 12mm plywood.
akuhenrikkorhonen
Postby jolly olly » Wed Jun 25, 2008 11:43 pm
hello there if you remove the door card first to see what shape and size you need my mate picked up a decent set that fitted straight in for about £45 a few years back, all i have ever done is to add in 2 extra speakers mounted to my bulk head (do you have a bulk head) if so you will get a better sound if you make a box to house the said speakers and if so make a bigger hole than you need to feed your speaker cables through as this also helps the speakers work better. Have you fitter a different sound system (none ford) if so did you cut the wires or fit a wirering harness, if you are using or going to upgrade get a harness as it is so easy to add in another pair of speakers if you would like a few pics pm me with your email and i will try to send you some pics as soon as possible.
I hope to of been some help cheers
Life is not a dress rehearsal
jolly olly
Postby akuhenrikkorhonen » Sun Jun 29, 2008 9:28 am
My project is progressing...So far I have:
- Installed 2 sets of Pioneers 6.5" separate way speakers, one into the doors and other set into the roof card
- Fitted/installed 12" Pioneer subwoofer+enclosure into the screen between the trunk and the cockpit
- 1000w 4-channel amplifier is feeding the subwoofer and speakers in the roof card
- Removed the original ford-player and replaced it with Pioneer mp3- player
How can I add some pictures into this post ???
akuhenrikkorhonen
Postby AndyG » Fri Jul 04, 2008 5:15 pm
akuhenrikkorhonen wrote:How can I add some pictures into this post ???
viewtopic.php?f=29&t=2560 :wink:
Re: Transit audio system
Postby nige » Sat Jul 05, 2008 10:53 pm
ive fitted some speakers above my head and passengers in the roof lining they sound great.
See no Sprinter fear no Sprinter
GAFFA TAPE IS A VANS BEST FRIEND!!!
nige
