use a mk4 one and put a mk5 centre in as the mk4 has the sport looking bit
in sted of the mk5 grill is flat mine will have the mk4 frame with the centre a mk5
AlanN wrote:I look forward to your progress
intransit89 wrote:finshed plastic welding the gaps and then gave it a rub down with sand paper then put some fiber glass on![]()
not looking to bad at mo![]()
MrMPuk wrote:intransit89 wrote:finshed plastic welding the gaps and then gave it a rub down with sand paper then put some fiber glass on![]()
Looks like a Mk5 grille.
Gurj51ngh wrote:MrMPuk wrote:intransit89 wrote:finshed plastic welding the gaps and then gave it a rub down with sand paper then put some fiber glass on![]()
was just thinking that. its just the side parts are a different mould.
MrMPuk wrote:
He'll probably change them next.
