REAR DISC CONVERSION
Postby WRECKERSTEVE » Tue Jul 15, 2008 3:57 pm
one for you luke i have a brand new transit van in my care at the moment twin wheel with a fridge on the back and surprise surprise its got rear discs now the question is can these be fitted on my swb mk5 with the same style rear hubs and bearing a late 5 stud axle would fit ?
you break it i take it
WRECKERSTEVE
Re: REAR DISC CONVERSION
Postby Luke » Tue Jul 15, 2008 8:25 pm
yeah ive seen the later mk7s with rear disks but no a close enough look to see if they would fit easy - the one ive seen wasnt the same style axle as the mk5 so it wouldn't go easy :(
post up some pics and we'll have a look :D
Postby WRECKERSTEVE » Wed Jul 16, 2008 8:19 pm
i agree its a much heavier axle casing but still on leaf springs rear uj similar so prop shouldn't be a problem the major problem would be the casing converting it to single rear wheel not sure how different the casing might be check with the local dealer who i worked for and will post pics soon
WRECKERSTEVE
Postby WRECKERSTEVE » Fri Jul 18, 2008 12:08 pm
pics Imageof the 08 transit axle ImageImageImage
WRECKERSTEVE
Postby duncr » Fri Jul 18, 2008 10:15 pm
instead of converting would an axle swap work? as there must be some of these getting stripped :?
Daily transport !!! as my other cars are .....................F**KED
duncr
Postby WRECKERSTEVE » Tue Oct 07, 2008 5:34 pm
picked up 57plate t350 140 single wheel 5 stud disc fitted as standard any one know if and how much wider this axle is compared to the mk4 on my bus ??
WRECKERSTEVE
Postby lostpaul67 » Tue Oct 07, 2008 6:07 pm
£400, 5.11 ratio in Nottingham......under 2 hours left
http://cgi.ebay.co.uk/TRANSIT-VAN-REAR- ... 286.c0.m14
T260/130ps Glx
My Mk7 Ford Transit161k miles
lostpaul67
GLX Posse - Founder member
