heres the list
a sheet of cardboard.
some scissors.
felt tip black might be best .
angle grinder.
welding clamps.
welder.
cuting disk.
grinding down disk.
a wire grinding disk.
some body filler.
some 1.5mm steel
right 1st of you get your sheet of card like in the pic
then cut it in half
then on your bonnet mark some lines ie on my bonnet i used the two big lines.
then put your carboard under the bonnet
then get your pen and draw around your bonnet shape
then pull your carboard out of your bonnet and you should have something looking like this
now we geting some where
now after you cut your template out like this
get some steel ie 1.5mm or 1.mm iam only useing as iam waiting for my steel
and draw around it
now get your angle grinder with a cutting disk on or use a jigsaw your choice after cuting it out should look like this
then just grind some of the sharp edges like i have to make it flush
then when you donw that put it next to your bonnet and clamp it to you bonnet and see if it fits ok
thats as far as i got so far but will up date
it would of been clean the paint of the bonnet where you gona weld your plate on then grind down the welds and then a skim of body filler then sand down then primer it then when you done that on both sides respray your bonnet
but yes i will up date some more
