Motorsport steering wheel boss
Postby gasretro » Sun Nov 02, 2008 10:22 pm
Guys i have a Ford Motorsport steering wheel that i'd like to fit to my 97 Tourneo, it has a boss with hexagonal slot for column (mk3/4 XR3i etc) my van is splined column, what boss do i need to fit? MK1 Escort?, Mk2 Escort?, MK3 Capri?, other???
Gav
gasretro
Re: Motorsport steering wheel boss
Postby Luke » Sun Nov 02, 2008 10:26 pm
mk1 escort or capri (both same) :D not mk2 escort :D
and post pics when its on :wink:
Postby gasretro » Sun Nov 02, 2008 10:31 pm
Cor blimey that was fast.................. will do thanks :D
gasretro
Postby Luke » Sun Nov 02, 2008 10:34 pm
you will have to slightly mod it as the later transit colum has a raised splie - either grind that off or cut it out of the new boss :D but the splines are exactly the same :D
viewtopic.php?f=18&t=1619
Postby intransit89 » Tue Nov 04, 2008 10:58 pm
Luke wrote:you will have to slightly mod it as the later transit colum has a raised splie - either grind that off or cut it out of the new boss :D but the splines are exactly the same :D
http://fordtransit.org/forum/viewtopic.php?f=18&t=1619
i got a mini metal file and its only about two or one splies on the escort mk1 boss is what i did and it fit 8)
the old sayings on here goes if inty89 can do any one can :lol: :roll: :P
intransit89
