having a tourneo means i have a headlining with soundproofing retained by big push clips so locating the roof ribs seems quite easy, but with the ribs being in the wrong location i thought about bolting a strip of ally 5" wide from the first (would be bulkhead) rib to the last and fitting the flip downs to that, this could also mean routing cables wouldnt require removal of the headlining.
i also need the 1st monitor clear of the rear aircon/heater controls which are roof mounted, mounting a monitor directly to the rib would obscure the controls.
has anyone done anything like this?
i fancied a 10" screen, do they move much when used in motion?
cheers
examples.............
