Hi,
plan on insulating my transit and using it to sleep in occasionally.
am fitting a a rotating etractor fan (fletner tcx-2)
using 1" kingspan (solid foam boards with foil cover) glued to metal panels
my question is what to use as a moisture barrier
1) breathable membrane as used in houses (black and blue felt like stuff)
or
2) a plastic membrane that is not breathable
6mm plywood then over the lot
cost is not an issue as I have both available (leftovers from various family builds)
thanks,
pj
