Quick question re floor removal
Postby rob.b.666 » Wed Dec 31, 2008 7:38 pm
Am currently stripping out the rear of my Mk5 LWB. Next task is to take the loadspace floor up, to clean and waxoil underneath etc.
One question, what holds it in place ? Can't see any fixings around the perimeter (was getting a bit dark by then though !), but don't want to go forcing it, if there's something simple I'm missing !
Any advice welcomed.
Cheers.
Rob
Transit Mk5 LWB Hi-Top
rob.b.666
Re: Quick question re floor removal
Postby Luke » Wed Dec 31, 2008 7:44 pm
do you mean the wood ply lining :?:
Postby rob.b.666 » Fri Jan 02, 2009 12:56 pm
Yep.
There's nothing in the workshop manual about it.....that I can find, at any rate !
rob.b.666
Postby Luke » Fri Jan 02, 2009 3:46 pm
it's not factory thats why - all ply lining was done after the van left the factory :D
it's usually fitted by self tappers but quite often over the years the heads get covered in crap and worn into the ply they are hard to see :)
Postby whitevanman66 » Fri Jan 02, 2009 3:50 pm
if your really lucky,then they have torx heads on them just so you have to go shopping for screwdriver heads
whitevanman66
Postby rob.b.666 » Fri Jan 02, 2009 7:35 pm
Got the floor up. Only half a dozen phillips headed screws in the end, all of which came out, without rounding off !!!
Floor is remarkably clean underneath. Toying with flipping floor over now, with a couple of new cut outs and re-laying, as it's like new on the other side !
rob.b.666
Postby rob.b.666 » Fri Jan 02, 2009 7:41 pm
Load space all clean now ! Now have a head full of ideas, re what to do with all this space !!!!
Anyone know where to get carpet/lining at reasonable cost ?
rob.b.666
Postby Bill£ » Fri Jan 02, 2009 9:10 pm
rob.b.666 wrote:Anyone know where to get carpet/lining at reasonable cost ?
Hi Rob,
I got a large "off cut" roll for my camper conversion at my local Carpet Right store. A good heard wearing carpet for less than £30 !!
Most carpet shops will sell off cuts large enough for van and you might get some very good deals with the sales on!!??
HTH
Bill£ :D
Bill£
