i may try and do some axel swaps as my white van was scraped my mates kep my front axel seing as the back one was sold on here
the thing is for the rear is it just undo the brake pipes.
the hand brake cable.
the bottom bolts on the shocks and leaf spring front mounting bolt and the rear spring shackle and prop shaft?
and put the 5 studer in place and re bolt up using the 190 leaf springs would be best i think not sure tho
as for the front axel
would it just be the flowing
is it just bottom ball join bolt.
undo the 4 bolts on shocker.
track rod end of take all the hub of in other words and take the brake pipe of with the union bolt?
then put the 5stud hub back in?with the 5 stud brake caliper.
but will the union bolt fit stright in to the 5 stud brake caliper as iam not sure if thay the same size etc ie 6 stud and 5 stud
