mondeo clocks,
mondeo clocks,
Postby DOL » Sun Jan 18, 2009 9:42 pm
jus fitted mondeo clocks in Donnas transit and all works ok but the fuel gauge reads full when the ignition is on then starts to drop when its turned off :? ive fitted 3 sets in other vans and not had this problem b4 but they were 2xp regs and an n reg,Donnas is an r plate(if this makes ny difference) :D anybody any ideas or had this problem :?:
Image 1 by 1 the penguins keep stealing my sanity!!
DOL
Formerly known as Dafodol.
Re: mondeo clocks,
Postby stuartrobbie » Sun Jan 18, 2009 10:30 pm
when i fitted mine, i had to take the glass cover off, fill the tank full, then take the arrow off and reposition it till i rose to full. trial and error, go to far and it will only read 3/4, you have to get it just right that it doesnt stop at full even though it wants to go more. if you know what i mean?
i still get the same amount of miles to the tank so its near enought for me.
i know this isnt the right way to do it but it suits me. the only problem i have, is it has different circuits on the back so the orange light doesnt shine up when im running low.
I don't switch my lights on... I turn the dark OFF!
stuartrobbie
Re: mondeo clocks,
Postby MinorMatt » Mon Jan 19, 2009 10:26 pm
Yes I think the fuel guage changed throughout the years.
You need to fit the earlier sender unit, or live with it
Re: mondeo clocks,
Postby DOL » Tue Jan 20, 2009 9:37 pm
MinorMatt wrote:Yes I think the fuel guage changed throughout the years.
any idea what the earlier sender unit is from or a part code,i could probably live with it but its the wifes van n you know what women are like :D
DOL
Re: mondeo clocks,
Postby MinorMatt » Tue Jan 20, 2009 9:54 pm
No Idea
You will have to go to frauds :(
Will be whats fitted to mine though - N569 FLE
Or you could get one out of the scrappers? I think it probably changed at the same time as the speedo drive (cable/electronic) you want one from a van with a speedo cable.
Re: mondeo clocks,
Postby DOL » Tue Jan 20, 2009 10:15 pm
MinorMatt wrote:No Idea
sounds about right mate as ive done this mod to my van which is a p reg and an n reg and another p and they all work fine,might wait and see if anybody has just swapped the gauge(or i might try it myself,got noet to loose really it either works or it dont :wink: )
DOL
