I was part way through collecting the bits when this appeared, since then I've got it all !
Bottle & tubing is from a Scorpio (not Granada Scorpio
), washer jets are from a Granada (mk3).
I offered the bottle up, inside the engine bay behind the o/s headlamp, it was o.k. but I couldn't attach it properly it interfered with the cold air inlet and the drain tube from the scuttle.
So I offered it up under the o/s front wing & it looked promising.So I removed the headlamp & bumper corner, then started cutting metal
Unfortunately I didn't measure just guessed so cut more metal than strictly necessary(but it is awkward to get the cutter in).
Thats it in the final position I ran the tubes (which I had left as long as possible when I cut them out). They were barstewards to connect up, because of the different diameters.
I extended the wires from the pump and level indicator & spiral wrapped them.
They go through the bulkhead along with the cables for the cruise control.
I did away with the big blocks that hold the jets to the chassis rails on the Granada and just used the flat jet holder, offered it up, marked it up drilled through and 2 self tappers to the bumper, then that went back up.
Bit awkward to fill but I'll remove the headlight again & use a heat gun to soften the plastic filler & try twist it into a better position. Only got the passenger side jets to install now.
