Twins on MK3
Twins on MK3
Postby AlanN » Wed Feb 25, 2009 1:04 pm
Has anyone seen twin headlights on a MK3? Its something I have been looking into, but it means doing away with the indicator...
The MK4/5 headlamps are much wider and I dont want to cut the bonnet to fit the ccm type.
Re: Twins on MK3
Postby AlanN » Thu Feb 26, 2009 10:35 pm
Looks like this is going to be a first then!!!! Will have to wait until later in the year. Now, wheres that BMW with the halo's
Re: Twins on MK3
Postby Luke » Thu Feb 26, 2009 10:40 pm
Alan i think this is the closest we've got :lol:
intys photochop :D
Re: Twins on MK3
Postby AlanN » Thu Feb 26, 2009 10:46 pm
They look like Capri RS clusters... Ive already got a MK3 Capri support bracket wit twins, the angles are all wrong, so I want to try BMW e30 clusters next, but they are so expensive :( breakers want too much so Im just nosing around fleebay for a cheap one just to try out
Re: Twins on MK3
Postby AlanN » Thu Feb 26, 2009 10:47 pm
Mini-lites look good 8)
Re: Twins on MK3
Postby MinorMatt » Thu Feb 26, 2009 11:33 pm
what are you going to do with the indicators Alan?
How about a strip under the headlight?
Re: Twins on MK3
Postby chunkychap247365 » Thu Feb 26, 2009 11:34 pm
good sodding luck mate! :D :roll: :lol: :!:
chunkychap247365
Re: Twins on MK3
Postby AlanN » Fri Feb 27, 2009 9:28 am
Ahhh! Im glad your on here chunkychap, I was going to ask your advice on this one, never used fibreglass for moulding before....
Looks like Im going to use BMW e30 lamps and brackets, as the lights are stepped one in front of the other at an angle that is similar to the van body and move the indicator to the bumper or as Luke says, LED strip.
I was going to use the old headlights as part of the moulding...
Edit: "Matt says" not Luke....
Re: Twins on MK3
Postby intransit89 » Fri Feb 27, 2009 8:13 pm
iam looking in to making some to for mk3 and mk4 :lol: :roll:
is it with these twin lights ie
1st hole next to ind is for parking light and one next to gril for high beam :idea:
i know for ind i was thinking spray it same colour as the van with plastic primer so on and then put 3 leds in or a land rover orange light dono yet
opps..
ITS CHRISTMAS
:lol: :lol:
:oops:
intransit89
Re: Twins on MK3
Postby BROWNYS V6 » Sun Mar 01, 2009 9:11 pm
alan are these what your looking for :?:
BROWNYS V6
Re: Twins on MK3
Postby AlanN » Sun Mar 01, 2009 10:31 pm
Hi Paul, yep, that looks about right, can I swap you for a MK3 Capri one :?:
Re: Twins on MK3
Postby WINDSCREENGUY » Sun Mar 01, 2009 11:55 pm
aint they 5 series ones not 3?
formally grey van man.
2010 115 semi high mwb . Fully loaded.
WINDSCREENGUY
previously grey van man
Re: Twins on MK3
Postby AlanN » Mon Mar 02, 2009 9:42 am
I think e30's fit several bmw's, but it will be worth a try
Re: Twins on MK3
Postby chunkychap247365 » Mon Mar 02, 2009 8:51 pm
Bmw e30 lights are 5 3/4 inches which are a very tight fit within any transit shape head light. what you realy need is either a 5 or 4 1/2 inch light unit which only come in sealed beam units hoo hum.
Golf inner light units are only good for being main beam and won't pass MOT test for dipped beam. There are a few options if your willing to pay for it. I tryed a few from ebay dominator twin bike lights but only give a flat beam pattern which not all MOT testers are happy with but it's a grey area. you can get round this by tilting the unit to the left. Capri lights are an option but again it's getting hold of the buggers in the first place.
I've put all my head light ideas on hold for a while as I've lost a job and gained a busness which means the development has been mothballed.
Top tip YOU CAN NOT EVER USE TO MUCH RELAESE AGENT WITH FIBRE GLASS MOULDS!!!!!!
chunkychap247365
Re: Twins on MK3
Postby AlanN » Tue Mar 03, 2009 9:24 am
At the moment, eveything I have tried, means removing the indicator (fit one in the bumper) I started with the Capri bracket, as I know e30's can be made to fit, but they are to flat to the front of the van... Thats why I going to try the BMW ones... Im also looking at peugot projectors, but nothing secondhand or cheap enough just to play with.
