18" alloys on a mk6
18" alloys on a mk6
Postby Gavin-T » Thu Mar 05, 2009 11:04 pm
I keep looking around for alloys for my mk6 and its either 15 or 16" van alloys or pay through the nose for sport van alloys.
However i have found that land rover discovery and 1995 onwards range rovers have a offset of 57mm so with a adapter of 25mm this would still be 32mm.
Would this be enough with a 8" wide rim and 235 tyres to keep inside arches of a mk6?
I have also found these tyres http://www.camskill.co.uk/products.php? ... 0s258p9080 could i run these on my van safely? Its a low roof swb 280.
Many thanks.
Gavin.
Gavin-T
Re: 18" alloys on a mk6
Postby Luke » Thu Mar 05, 2009 11:08 pm
where do you get the 57mm from :?:
i dont think you have the right measurment if you have 235 tyres then they are 235mm wide ET57 would make them stick out 60mm then 85mm with the adapter :(
i dont know of any mk6 that has adapters and the wheels anywhere near under the arch :)
Postby Gavin-T » Thu Mar 05, 2009 11:13 pm
http://cgi.ebay.co.uk/Range-Rover-alloy ... 240%3A1318
The landrover alloys have between +55 to +57mm offset so a 25mm spacer would bring this down to between +30 to +32mm offset.
Gavin.
Gavin-T
Postby Luke » Thu Mar 05, 2009 11:18 pm
other way mate :( the adapter would make it more doesnt matter wether it has a + or - offset :)
the way to fit landrover alloys is redrill the hubs :D
Postby Gavin-T » Thu Mar 05, 2009 11:23 pm
You sleepy tonight mate?
Say the landrover wheel bolted straight on it would be 55mm in from zero offset? With a 25mm spacer it would 30mm from zero offset?
This is how i have pretty much known it all to work.
Wheels on my old escort were +35 on the back and +49 on the front and the rears were a lot more dished, while the fronts sat in a fair bit.
When i had my old discovery i went from +33mm to +8mm and the wheels sat out a lot more.
Gavin.
Gavin-T
Postby Luke » Thu Mar 05, 2009 11:32 pm
i see what you mean, transit ET is 45 whats the widest tyres you can fit :?: your still gonna be past that and then theres the thickness of the tyres :? someone measured the hub face to arch edge and its posted on here :D
try it :D you wont have a problem with the weight on the alloys and you can fit lower profile tyres :idea:
Postby Luke » Thu Mar 05, 2009 11:34 pm
there is 50mm from face of hub to outside edge of front wing
dont think it will fit :(
