basically i sourced a mk6 wheel from the scappy and stripped it,
cut out the centre of the scrap wheel (to keep the boss/column fittings for later)
sourced a solid piece of aluminum bar around 6" high and a width to match the underside of the new wheel
mill out the underside of the new bar to fit the old wheels center inside thus retaining a strong and standard fitting wheel
make a hole through the center of the bar to allow cables for the horn etc
drill and tap mounting holes for new wheel at top of new bar
connect old horn wire to new steering wheel
pictures will follow soon of dismantled boss..
